SOURCE: Clutch pedal stayed down when shifting
To Fix: Set the preload on the throw-out lever. You can also try bleeding the clutch.
Problem: Its the problem with the throw-out lever or there is air in the clutch line.
Hope this helps ya!
SOURCE: brake lights stay on although the brake pedal is
You will probably find it is a problem with the switch on the brake pedal.
Get your self a cheap multi meter from an electronics store. Set it to meaure ohms. This is used to check if a connection is complete.
Take the wires off the switch on the brake pedal and test if the connection is open or closed. Push the pedal and check the connection again.
If the switch only had one wire then the negative connection is made to the body of the car. Put one probe of the volt against bare metal of the body somewhere and the other agains the terminal of the switch and test again.
This should tell you if the switch is broken. if the switch is good then you probably have a short circut somewhere between the brake lights and the switch. That is something has pinched or other wise broken the wire and it is touching metal of the car. You will have to follow the wires as best you can and look for damage.
Hope this helps
SOURCE: clutch pedal went to the floor but did not come
there is a plastic clip that connects the clutch pedal to the rod that goes to the master cylinder, chances are that it let go. Bad thing is that it is only available from GM along with the rod. It is around 50
SOURCE: Why does my 91 VW Jetta stall out and lose power while driving?
I had a similar problem and the mechanic diagnosed it as a problem with the ignition coil. So you might want to get that checked.
Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- The engine may stumble or stallPossible causes- Ignition/Distributor engine speed sensor harness circuit is open or shorted
- Ignition/Distributor engine speed sensor poor electrical connection
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Low battery charge
- Faulty Engine Control Module (ECM)When is the code detected?The P0322 code is triggered when the Engine Control Module (ECM) detects no signal.P0322 VOLKSWAGEN DescriptionIgnition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If ECM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
