Question about Ovens
GE Microwave Cooking Center JTP85
We just ran the self cleaning system and the door will not unlock. Ran it a second time the next day and stillno luck.
We then shut off all the power to it by hitting circuit breaker and turning back on a few times. Still no luck.
Other than that, we have had no problems with the oven. Its about 7 years old.
Is there a secret code I can enter that will unlock the door? Any ideas? Turkey day is coming quick!
Dave Deputy
  • Anonymous Mar 18, 2009
    GE Microwave Cooking Center --- SAME PROBLEM, DIFFERENT MODEL [JKP76] -- door will not open, and the unit [both the micro and the conventional oven] is COMPLETELY "dark" -- ie, the control panel does not light up.
  • 68 Answers
SOURCE: GE Profile Spectra Electric Oven Self clean malfunction and F7 error
I can't help with the burn marks, but have considerable experience with the F7 problem. Click on the following link for my solution:
I have now shared this with over 1400 folks and most report success. Please let me know if this works for you.
You can email me at
Posted on Nov 22, 2007
SOURCE: F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Posted on Dec 16, 2007
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
SOURCE: whirpool rbd275yPDT11 no power after auto clean
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Posted on Jul 06, 2008
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ... > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ... > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
I locked the door on my GE rapid clean II and ran the cleaning cycle and now I cannot get the door to unlock. Any ideas?
Try to open it in a few hours or in the morning, I think it has to cool down before it will open the door.
If that fails run the self clean cycle again perhaps a second try will get it loose.
Aug 17, 2011 | GE Ovens
Our Kenmore oven door is showing "locked" and will not open, the model number is 911.4568816. We have ran the self cleaning system 3 times hoping it would unlock afterwards. We have also...
well a couple of things could have happened one the relay timer is broke on he oven and doesnt know when to shut off until done, the stove goes off I hope on the self clean ? if so then the relay that locks the door closed is stuck or the fuse blown that triggers the soleniod .so the approach would be to shut the power of or unplug and see if that releases the solunoid lock ,if not you will have to take up the top it just lifts up and get to the door latch that way. And if still no luck stay powered down and take back panel off and check out wiring diagram on panel an see how its wired and what goes to the door latch and if all else fails call sears hotline. or check online -google it some eelse has had this probleem before or even call and appliance parts store and they will tell you whats wrong with it cause they waant your business
Jun 30, 2011 | Ovens
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
RE: GE cooking center microwave JKP85 - there is
I have exactly the same problem. I take it no one has offered a solution to this. Don't know if this is a lining coming loose and potentially dangerous. Anyone know?
Jul 05, 2010 | GE JKP85 Electric Double Oven
I ran the self-cleaning and the door will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Mar 06, 2010 | Whirlpool Ovens
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
Cannot unlock self-cleaning oven
I ran the cleaning cycle again, and it the door opened without difficulty.
Sep 13, 2009 | Kenmore Ovens
Ovens Logo
483 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
