I'm Guessing your using Ubuntu 7.04... Due to a bug in the native driver shipped with Ubuntu, the
wireless card on this laptop is detected and installed but you cannot
find any wireless networks. Here’s how to fix it.
* Let’s disable the native Ubuntu driver. Type this in a terminal:
gksu gedit /etc/modprobe.d/blacklist
and insert at the very end of the file:
# buggy broadcom wireless driver
blacklist bcm43xx
* Next, do this in a terminal:
sudo rmmod bcm43xx
* Now, let’s download and install the windows driver for the
wireless card. You have to download it from the Dell support website.
Click
here to download it.
Or you can use the direct link to the executable:
http://ftp.us.dell.com/network/R140747.EXE
Since it’s a windows self-extracting executable, you need wine to use it:
sudo apt-get install wine
then:
wine <path_to_R140747.EXE>
Replace
with the actual physical path to the file you downloaded from the Dell
support website. Follow the instructions and extract the files to a
folder of your choice. Alternatively, you could extract the files on a
windows machine and copy them over to your ubuntu system.
* Now, let’s install ndiswrapper. We need it to load the windows driver.
sudo aptitude install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
* Let’s install the windows driver:
sudo ndiswrapper -i <location_of_bcmwl5.inf_file>
Replace <location_of_bcmwl5.inf_file> with the path to the bcmwl5.inf file you extracted earlier.
* Let’s make sure the driver is installed:
sudo ndiswrapper -l
You should get something like this:
bcmwl5 : driver installed
device (14E4:4311) present (alternate driver: bcm43xx)
* Now we need to set up ndiswrapper to load our new driver automatically:
sudo gedit /etc/modules
and add a new line that says:
ndiswrapper
That’s it, restart your laptop. During the restart, the wiFI LED
should light up. If it doesn’t, try the Fn + F2 key combination. After
the reboot, configure your network settings:
System -> Administration -> Networking
Enable the wireless connection and tinker with the connection
settings if you need to. You may have to disable the wired connection
because wireless and wired connections may not work simultaneously -
your mileage may vary in this regard.
Note:
It seems Network Manager prevents the card from connecting to detected
wireless networks. I advise you to remove it if you can detect wireless
networks but cannot connect to them. To do this, type the following in
a terminal:
sudo apt-get –purge remove network-manager network-manager-gnome
Alternatively, you can open Synaptic and remove these two packages.
* Summary:
1.) Install ndiswrapper
sudo apt-get install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
2.) Install the windows wireless driver
Remember to replace <location_of_bcmwl5.inf_file> with the actual path to the location of the bcmwl5.inf file
3,) Make sure the card has been detected and installed
ndiswrapper -l
4.) Disable the native ubuntu wireless driver
Insert at the very end of the file:
blacklist bcm43xx
5.) Remove Network Manager if it gives you problems
Reboot
You wireless card should be working flawlessly now.
I Hope this helps :)
Cheers
Jasonjohn89
