Question about Whirlpool Duet GHW9150P Front Load Washer
Ghw9100lw1 The ghw9100lw1 door is open but the lock is closed and the washer will not start
  • bshaink Jun 29, 2008
    My son pushed in the latch where the door would go into - now the latch is in the closed position keeping the door from being able to be shut. I can't seem to get the plastic piece to go back up to allow the door to close again. Holding the end of cycle did not do anything.
Try holding the End of Cycle Signal button for about 3 seconds and see what happens. Mine started working again.
Ok Yankee
Posted on Nov 17, 2007
I am getting a f26 code and my washer wont start when I press start
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 23, 2010 | Kenmore Elite HE5t Washer
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Cannot get washer door to open.
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW1 W/POOL WASHER
if dorr does not lock then the fault is door interlock
Dec 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
415 people viewed this question
Dan Webster
Dan Webster
Sal De
