-   bissell quicksteamer 1960 series 2070 series quicksteamer powerbrush
Will not spray water. Cleaned it really good. Still will not spray water. Please help.
-   Guest
Dec 02, 2008
-   My Flip It is only 6 months old and barely used it will not spray the water either and its too late to return to Target has not been helpful in this what warranty did I have to begin with??? we have tried everything yet do not want to ttake apart because its new...-   elsita3000
Nov 29, 2008
-   My bissell will not spray water either, I have tried everything. I have cleaned all the filters and liquid container..removed the front and cleaned the entire cleaner...it still will not spray the water but will vacuun
-   alleyezon462
Feb 29, 2008
-   Spotlifter powerbrush 1716 series
it will not spray water or shapmoo-   Guest
if this is a new model take of the handle ,If you look down were the handle plunger fits into machine you should see a valve.
press the top of the valve in ,if the machine sprays water then the fault is the handle plunger is not making full contact with the valve, ad a small pad to the end of the handle plunger ,
this should make the machine work
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way....
(More)
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way. We have used an oreck and the kenmore intiution. Both of these vacuums are very hard to push on this carpet. It gives you more than a workout for the day. Any recommendations??
my kenmore intuition vacuum seems to have lost suction and the check bag light comes on. the bag has...
(More)
my kenmore intuition vacuum seems to have lost suction and the check bag light comes on. the bag has just been changed (2x). cannot see if there is any type of blockage. any ideas? thanks.
ps. only had this vacuum for 3 months.
