Question about Emerson EWF2004 20" TV
Remote control The remote control does not work. I have cganged the baterries, and even tried a universal remote. I feel the problem may be in the TV sensor. Can this be repaired easily and cheaply?
  • 39 Answers
Re: remote control
Posted on Nov 21, 2007
0 characters
3 Points
I have a Toshiba TVs that I lost the remote I bought a RCA universal remote model RCR3273R can get it turn TVs on and off but can not get input button to work
Some universal remotes control some TV functions but not all. You may have to do a code search to find another code that will work with your Toshiba TV. It may be necesary to try another universal remote or even a replacement OEM remote.
Dec 22, 2014 | Standard (CRT) Televisions
The universal remote RCA codes
0928,0922,0925. Try these codes. For more information If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. For more information; check and find which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability
Nov 23, 2013 | Konka K1318U TV
I was trying to test a universal remote on my sanyo tv, it didnt work, but now my sanyo remote that came with the tv doesn[t
For your original remote control, try to remove the case of the remote control then check the battery terminals that is connected in the pcb board if loosed, then for the sensor if you have a cellphone with a camera point the sensor in the camera and try to press any button you will see a glowing red light if no your sensor is defective. But be sure to assemble your remote and replace the battery.
Jun 25, 2011 | Sanyo DS24425 24" TV
Same problem as above.Disney p1310ATV lost the remote. No Phone # in orginial manual.Television system NTSC (American TV Standard) I have tried other universal remotes also I have a Sony RM-V210 universal...
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
Jan 02, 2011 | Disney 13" TV
The Emerson TV won't respond to the remote
If the Duraband doesn't work the Philips remote below worked on mine. If it doesn't then it probably is the sensor. I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
May 11, 2009 | Emerson EWF2006 TV
Universal Remote for this TV?
I usually recommend a GE universal remote... They are known to work for even the most stubborn televisions. I have no problem making sure you have the right code for your TV
May 04, 2008 | Quasar VV2507 25" TV
Daewoo CTS 2090
try this ENTER MUTE PR UP PR DN ENTRE OR TV IN STAND BY MODE only do as AV SLEEP CLEAR POWER buttons on user remote with in 10 seconds. or go to web site
Sep 21, 2007 | Standard (CRT) Televisions
No response from remote
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Remote Control wont Work
did you spray the cleaning solution right onto the control panel?? Well if you did you may have shorted out your remote sensor eye. If irt dosent dry out in a few days then your gonna need a new one. Go to and they will assist you finding what you need. Good luck
Apr 23, 2006 | RCA 32V550T 32" TV
Emerson EWF2004 20" TV Logo
97 people viewed this question
Top Emerson Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Emerson Standard (CRT) Television Expert? Answer questions, earn points and help others
