Problem for Web Cameras
Generic problem for all Web Cameras
I have Mikomi Dc-6120 and the MIC...
I have Mikomi Dc-6120 and the MICROPHONE IS NOT WORKING
Solution #1
posted on Aug 30, 2009
Rank: Wiz
Expert
Rating: 82%, 2064 votes
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Click OK and it should work.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your Computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
Go to this site http://dashboard.aim.com/aim and Launch AIM AOL Messenger.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings,
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· Images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
web cam that works with vista 64 bit
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any...
(More)
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any suggestions?
what could be the problem with my pc when i have a message saying "no signal input or cable...
(More)
what could be the problem with my pc when i have a message saying "no signal input or cable disconnected"..i've been dealing with this problem for so long..sometimes my pc works but most of the time i get that message..any reply would be very much appreciated..thanks and more power..
i cannot use the cam thru the yahoo messenger or even in skype
Hi can you hel, i am getting the following message with my HP 5590 scanjet "hpqscnvw has...
(More)
Hi can you hel, i am getting the following message with my HP 5590 scanjet "hpqscnvw has stopped working"
