Sounds like the main board is going but also check to see if ground on battery is loose also check for corrosion on battery terminals check ground wire on alternator and have your voltage checked at a shop or local advanced auto or similar store have then hook the code reader to the mainbrain as well while ac is running and lights are on then check with car controls off this may give a clue or even solve problem
I will take it to auto zone in the mornining i have one close by
SOURCE: Car loses power while driving
You must replace the distributor cap and rotor button- easy fix. Do not mix wires up. Message me I will guide you through it. definitely know my stuff here.
SOURCE: pass. side trailer turn and brake lights out 1999 ford explorer
if your vehicle lights are working all the fuses will be good. follow the cable from the towing socket on your vehicle , it will most likely go behind one of the rear lights to connect into your cars system,
check your tester where the cables join and you should find the problem. hope this helps.
SOURCE: gauges go out, car runs fine, radio works, abs light on turn signal works
this is a body control module (BCM) fault, replace it..
SOURCE: 1999 ford windstar won't start,pulling hair out, HELP
remove the negative battery lead fr about ten minutes then reconnect. this will cause the computer to reboot
SOURCE: Have hazard lights but no running or turn signals
sounds like you need a combo flasher assembly..located in fuse block inside vehicle under steering column..there may be a plastic cover under dash you have to remove to see fuse block..large black relay that plugs into fuse block..if you pick up a new one,you will see what it looks like..available at dodge dealer..combo flasher or drl/signal relay
