Question about Alpine CDA-9856 CD Player
MP3 CD's So the player cannot play back some of the MP3 files on CD's, e.g. I insert the cd with 26 tracks in total and the player only finds first 11 tracks and they are the total for the player. It's quite strange since I'm sure that all of those files are definitly MP3 format. The CD's are completely new, no dirt nor a single scratch. Hoping for Your advice! Regards, Martin
  • 227 Answers
Re: MP3 CD's
Sometime when put too many file in a cd then the scond half of the cd get corrupt. Try play that cd in another player see if it work. Certain unit could only read certain compressed size file too small and it would be view as corrupted.
Posted on Mar 10, 2008
0 characters
3 Points
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Does alpine CDA7892 have MP3
Yes it does have MP3 capability.
In the set up menu (press and hold set up button for at least 3 seconds) you need to select CD/MP3 with the up or down buttons. Then use Band button to make sure CD/MP3 is selected and you can play back MP3s that are burned to CD and also ordinary CD tracks.
Thanks for using FixYa. Please do leave a vote for the solution.
Jan 24, 2011 | Alpine CDA-7892 CD Player
Cd player doesn't play mp3 files recorded on cd
Possible that the format you have recorded is not accepted by the player's specification. I would recommend that you re-reccord the files with MP3 compression that is accepted. Use another software - nero- should be fine. If this wont work but your audio files play Ok then it could be a fault within the audio processing section. Hope your get this right. Good day
Jul 06, 2010 | Blaupunkt Brisbane SD48 Car CD/ MP3 Player
How i can attach mp3 or memory card with my kenwood player
If the Kenwood is compatible with USB memory adapter, then you will have an USB port on the front side of the player, just aside the CD slot.
If the stereo is MP3 compatible, that does not mean that the unit is compatible with USB devices.
If the Kenwood is MP3 but not USB compatible, you can play MP3 files burning them onto a CD, then playing the MP3 CD in the CD player.
May 25, 2010 | Kenwood KDC-MP228 CD Player
When playing a burned mp3cd all I get is noise
It is the way it is burned. On the program you are using, it is set for all songs on one track, not sure about the noise. I recommend using windows media player 11. Go to media player, select burn, create list. Then drag all the songs from library to the burn list on right side, and hit burn. That's all there is to it.
Jul 05, 2009 | iLO XM-MP3-CD Car Stereo
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
My 1998 Jeep Cherokee cd player does not work, displays "error when cd inserted, the radio works fine, can it be repair?
it will read burnt cds, the only thing is that it will not play .mp3  format songs, if you can somehow change the format to something else it should work just fine. i had a friend who's car had the same problem and switching the file extension from .mp3 to something else like .mpeg or something else should work. the cd player in a 98 grand cherokee is older and does not have .mp3 play back on it so it cannot read .mp3 format files. that's the only reason it doesnot register. try different audi files out and it should work. give it a try. i hope that helps out some.
Dec 30, 2008 | Jeep AM/FM Cassette with CD Changer...
How to select differt folders in my mp3 cd fro pioneer player
Try going to the Pioneer website and find the DEH-p3900mp page. Click on the documents tab and click on owner's manual.
Dec 19, 2007 | Pioneer DEH-P390MP CD Player
Soundstorm SMP3-100R CD player
I have had this problem before with mine. I found that it was one of the tracks I had on my flash drive was corrupt, I don't remember which track it was but if I plugged my drive in it would play until it got to that track and then it would just swith over to radio or cd. I had the same problem with a cd I had burned a bunch of MP3's on. If you erase your flashdrive, reformat it and then try saving songs to it again that should take care of the problem as long as you find out which file has the corruption in it and you don't put it back on your flashdrive.
May 15, 2007 | Soundstorm SMP3-100R CD Player
Alpine CDA-9856 CD Player Logo
89 people viewed this question
Top Alpine Car Audio Receivers Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio Receiver Expert? Answer questions, earn points and help others
