Sometimes the timer display fades but still working in background, if all dead now then probably means you need new timer as ovens shouldn't work if clocks not set to manual mode.
Try turning oven on then messing with buttons, usually the 2 left buttons and one far right should do trick.. push 2 left first, keeping them pressed push far right!
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
If it is a digital timer and u have display, thenyou must make sure it is set to manual and not flashing auto, or the oven will not work.
If it is an anologue timer tweak the knobs until you can see a hand symbol showing this is the manual mode.
If no display of any kind, and u are sure u have a supply to oven then timer could be faulty.
Hope this helps.
U must ensure that u have a supply to the oven befor trying to alter timer.
Plz rate solution.
Thanks.
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
nextwave, looks like you have a safety thermostat (TCO) on the back of the oven. Should have a red and red/white stripe wire going to it. If this opens it will cut the power to the display, part number is 316003606. The hardest part of this gig is pulling the oven out to change the t-stat out. Catriver.
