SOURCE: Unlock My NET10 ZTE Merit phone
Press emergency call in idle mode and input *983*987#, it will go to the factory reset interface and customer can reset the handset to Default.
Note:Please do remember to remind the customer this method will delete all the personal information in the phone.
SOURCE: I need to know how to transfer different stuff
try do download a file manager on google play. Or if it already have one, you can open it. Hold the item you want to move until a pop-up appears select cut or copy. after that go to the directory you want to place the file and tap on options in the lower right and tap on paste.
SOURCE: how to switch from boost to straight talk phone and keep my number. backup contacts. photos. etc,?
Boost will port or release your number to use with a different carrier, if you go to any Wal Mart they should be able to walk you through it
SOURCE: how do i swap my ZTE Z796C phone from straight talk to att service
If your phone is unlocked, take it to an AT&T Wireless retail center and they will be very happy to help you. If your phone is locked, you will have first to ask Straighttalk customer service to unlock it and discontinue service.
SOURCE: How do I connect my Bluetooth to my straight talk zte quartz phone
1. enable bluetooth on the phone
2. activate sync on the bluetooth headset.
3. try "0000" as the code unless your manual says otherwise on the phone when it finds the device.
4. Try testing and see if your phone links correctly and you can hear audio either by calling yourself or by playing a media file if your phone is a smart phone.
