Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
TV Noise When the TV is first turned on, their is a static type of noise from behind the TV that is associated with bright pictures. It disappears after the TV warms up (about 15 minutes). What is going on?
  • drgnfire Jan 27, 2009
    I have the same issue with mine. I was told there is a board that can be replaced but I am not sure which one it is.
I was told that the noise issue is with the power supply board
Part number:1ESA13003
you can purchase it at https://www.encompassparts.com for about $170.00
I have not replaced mine yet. I am trying to see if I can get the part numbers off the transformers first so I can replace those (which is what i think the noise is coming from.
Posted on Jan 29, 2009
I hate to tell you this, but they all do it. I returned mine and the replacement does the same thing.
JJDS
Posted on May 05, 2008
Loud static noise when I turn the tv on
what tv what model what what ?? all detail is missing past a crystal ball ???? static noise is usually psu or eht sides
Nov 30, 2014 | Televison & Video
Y Component Cable Related - Internal Static Noise
It sounds like one of those cables has a defective ground. The static noise you are experiencing is cause by the cables not inside the TV. Try using different cables to isolate the problem and get new ones.
Good Luck.
Feb 17, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
Static noise and blurry screen
You need to take your TV set to Service Center, because the inner parts, especially the flyback transformer, been damaged or worse, the connector broken, that's why you can hear the noise.
Mar 07, 2010 | Symphonic ST420FF 20" TV
Our cd changer has begun making loud static type noise when you first turn it on. It disappears after unit has warmed up. Why? Any fix you know of?
the digital to analog converter ic is going bad. whatever you paid for this unit you might want to get it repaired.
Nov 07, 2009 | Audio Players & Recorders
My 55" sony Wega Model # KDF55XS955 let out a loud noise than the picture disappeared. Can you tell me what may have happened
Loud noise could be of any exhaust fans in TV.
Does TV go to standby when picture disappears? if yes, its standby light would start blinking, please count it and let me know to find out problem section.
Oct 18, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
114 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
