Question about Transcend T.sonic 610 MP3 Player
Power off asdfasdfasd
  • 8,596 Answers
Re: power off - Transcend T.sonic 610 MP3 Player MP3 & Digital Media Players
I understand
Posted on May 23, 2008
0 characters
3 Points
File transfer cable doe not recognize computer when connected to usb hub
Some USB hubs are "powered", some are not. If you have several different things plugged into the hub, you most likely need a powered hub, one that plugs into the wall for power. USB devices need power supplied over the USB cable, and one computer socket can't always supply enough power for several devices.
Oct 14, 2015 | MP3 & Digital Media Players
How do you switch on the Eclipse 180g2 mp3 player
RTM page 6 :>)
Power On/Off
To power the player on, set the power switch to the ON position, or press and hold the
PLAY button for 5 seconds, until you see the Eclipse screens. To power the player off,
press and hold the PLAY button for 5 seconds, or until the device powers off, then set the
power switch to the OFF position.
May 02, 2015 | Eclipse 180g2 4gb mp3 music/vid
Replacement power supply for Sony Digital Media Player Model NWZ-E344
All you need to know is how poerful your computer is, that is find out how much power the equipment installed is using, then you can replace the power supply with one that meets the computer needs.
Make sure of the type of power supply connector you have Atx etc.
You can go with any brand, so as long as it's the correct connector type, and it has enough power to run your system.Things to note is the manufacturer of your graphic card, and the processor type, as they have different power requirements, graphic cards are usually the most demanding.
Mar 17, 2013 | Sony Walkman NWZ-E344 Digital Media Player
My ipod touch 1st generation says it's disabled for over 1 million minutes. How can I reswt it or get it working again?
ok heres what you need to to but it only works once so get it right the first time and dont do wat you did again. here is what you press. box, power,power,power,power,box,power,box,box,box then press and hold box and power together
Dec 22, 2011 | Apple iPod touch 1st Generation (8 GB) MP3...
I have power to the acc wire to the radio, but no power to the all time hot, I can't get any power to turn the radio on. I also don't have a diagram to check the fuses.
You shouldn't have any power from the acc wire. That wire is switched by the radio as an output if you had an accessory such as a power antenna or an amp.
Jun 17, 2011 | MP3 & Digital Media Players
Reset the device. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Power cycle the device.
The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
STEP 1 - Remove the battery STEP 2 - Power cycle the player 1. Connect the player to the PC. 2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device 1. Unplug the player from the PC. 2. Insert a fresh AAA battery into the player. 3. Turn on the player.
Dec 29, 2010 | SanDisk SDMX1 MP3 Player
Player will not turn on doesn't look like it is charging. Could the power cord be defective?
I wound first suggest you get a similar power cord to charge your mp3 player before concluding that the power cord is bad, if the similar power cord did not charge your mp3 as well, then, it means the power cord is defective. you can now go ahead to get a replacement for the power cord.
Take care.
Jul 05, 2010 | SanDisk Sansa e250 MP3 Player
Our ipod has a dark screen (won't power up) and doesn't seem to be charging either.
Check Hold.
If not, try to power up then hold left down while powering on.
Ipod touch- Maybe in DFU mode.
To exit, Hold the power button and Home for 10 seconds the relese the home button but hold the power button for 10 mor seconds.
It should power up.
Dec 30, 2009 | Apple iPod MA446LL/A MP3 Player
How do you turn it on
The power switch is at the bottom of the unit. However you must follow this combination to get the unit to power up
To power the player on, set the power switch to the ON position, then press and hold the PLAY button for 5 seconds
To power the player off - first press and hold the PLAY button for 5 seconds, then set the power switch to the OFF position.
Hope this helps. Thanks for using FixYa.
Dec 30, 2009 | Mach Speed Trio V430 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
Top Transcend MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Transcend MP3 and Digital Media Player Expert? Answer questions, earn points and help others
