Question about Garmin Quest GPS Receiver
NO voice commands from Quest
I am unable to get voice commands from my Quest. I got a new cord/speaker and still not working.
Re: NO voice commands from Quest - Garmin Quest GPS Receiver GPS Devices
Download latest voice patch
Posted on Feb 17, 2008
Did you solve your problem?
Posted on Jan 08, 2008
0 characters
3 Points
When driving no voice, check sound is fine
If you're just driving around and you haven't selected navigate to a destination there will not be a voice. Try navigating to a destination as that is where you will get voice navigation suggestions or commands. If you don't get a voice then, perhaps you need to download a voice or two. This can be done using the Garmin Express software and a computer connected to your Nuvi using the USB cord.
May 09, 2015 | Garmin nuvi 2555LMT
2014 F150 Lariat Sync Voice Command problem?
It sounds like it should go to the dealer for warrenty repair.
Aug 24, 2014 | GPS Devices
No voice command
Try going to the settings menu and look for voice options. Usually there is a box that needs to be checked for the option to work.
Apr 13, 2014 | Garmin nuvi 2555LMT
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS Devices
Hi our tomtom go 520 has stopped speaking to us. It is not the volume thats turned down, suspect it may be the speaker as it was squealing. Thanks, john
Normally the voice commands are only available in the "Computer generated voice" mode. If you select any other voice, the feature is disabled. Hope this helps
Oct 05, 2010 | Tomtom GO 520 GPS Receiver
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS Devices
I have a Magellan Maestro 4250 and touch screen not responding
Yes. The hard reset is the little pinhole on the left. Just use a pin and poke it. It should bring everything back to factory default and all saved info, addresses, routes etc. will be deleted.
Jun 07, 2009 | Magellan Maestro 4040 GPS Receiver
No voice command (nuvi 760)
Is there other sound? Have you tried listening for voice with a set of headphones plugged into the headphone jack? If you hear voice there, then your speaker is bad.
- Jim
Sep 16, 2008 | Garmin GPS Devices
Voice commands
Most likely cause is a faulty speaker . Very common. See other questions on Fixya where I ahve posted the solution.
May 26, 2008 | Tomtom ONE GPS Receiver
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
May 04, 2008 | GPS Devices
Garmin Quest GPS Receiver Logo
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
