Question about MPC Computers AOC 7F 17" CRT Monitor
Samsung 710M any body help me to solve my problem about my samsung 710M desplay apper just a second and i found out that inverter is not working. Thank you in advance.......
0 characters
1 Points
My Samsung Syncmaster 2033SN LCD Display flashes after every 5 seconds
Get in touch with Samsung support:
May 19, 2015 | Samsung Computer Monitors
I have a Samsung Syncmaster 710M that's about 5 years old. It had been lying around in its box for more than a year. When I tried to use it recently it shows the "Check Cable Signal" screen...
when you connect your lcd with computer and when you put on your computer after that press the source button on your lcd, then it will bring the display in front of you dear. thx
Jun 24, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
I need downloadabdle vga drivers
You can find the same from samsung Website, check in below given site
May 07, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
My Samsung SyncMaster 710m's built in speakers wont work can anyone tell my why and how to fix it?
you will need appropriate drivers installed
and you will need a audio cable - with male jacks on both sides to plug in the blue audio out line from the computer to the blue audio in line of the monitor
Nov 05, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
Jul 10, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
My samsung syncmaster 943 bwx turn black after few second turn it on.1st i thought is the software change it .but it seems not . I try to solve it since i noe some basic . waw gt many bad capasitor and...
When DC filter caps are bad, the circuits will get AC ripples feeding the inverter output circuits and caused it to run at worng frequency and caused it to over heated, hope fullly it did not take out the MOSFETs.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Jun 20, 2010 | Samsung 943T Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Syncmaster 910t blinks image perfectly once and goes back to black
I found a site that sells your (our) part: Look up that model number for the power supply under "Part #" and it seems to run about $60-70. I'm probably going to order one and give it a shot as a drop in replacement.
Oct 18, 2008 | Samsung SyncMaster 910T 19" LCD Monitor
MPC Computers AOC 7F 17" CRT Monitor Logo
46 people viewed this question
Top MPC Computers Computer Monitors Experts
Gareth Cockram
Gareth Cockram
Barrett Palumbo
Barrett Palumbo
 Mike M
Mike M
Are you a MPC Computers Computer Monitor Expert? Answer questions, earn points and help others
