Question about GE GSH25JFR Side by Side Refrigerator
GE GSS25LGMBCC Top of freezer is above freezing.
Top of freezer is above freezing. Rest of freezer and refrigerator seem to work OK. Seems like I used to hear a louder fan when closed the door. I don't here this anymore.
  • benjsarge Dec 13, 2007
    Have the exact same problem. evap fan still makes noise, condenser fan and coil are clean, freezer going into defrost everyday, will not freeze. FRig side ok
  • 72 Answers
Why doesn't my Kenmore Refrigerator/Freezer freeze food?
The compressor could be failing, especially if it was running when the power outage occurred.
Jul 15, 2014 | Kenmore Refrigerators
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
How so get the fan uptop in the freezer compartment to work, seems the fridge is working, the compressor turn on and the everything freezes and the lower section of the fridge does not cool.
You will need to unplug the wire connector to the fan motor and check for power, you should have 120 volts when the fan is in running mode. To get it running mode turn the cool to the coolest setting when opening the freezer door tape or hold the door switch closed fso the fan will try to come on. If the fan has power but does not come on replace the fan motor.Here is a link that should help
Sep 10, 2010 | Frigidaire FRT21H8 Top Freezer...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Refrigerator fan runs but nothing cools
Replace the start relay on the compressor.
Sep 01, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag MTB2156GEW Freezer works but refrigerator (lower part) not
Is the freezer fan working ? Is there frost on the rear wall , inside the freezer section ? If frost , in the middle of the control panel , you will see a hole slightly larger (1/2 " ) . Insert a screwdriver slightly into this hole and turn slowly until you hear a click slightly louder than the rest . Once you hear this click , stop . The freezer fan should be off ( you set it into the defrost cycle ) . Close the fridge door . Using a short extension cord with all 3 wires split (without bare wire showing) check the amps . 2 to 5 amps is good , this would indicate the heater and bimetal are good , also , indicates that the timer is probably bad . If you get no reading on the amp meter , then either the bimetal or heater is bad . Remove the inside rear freezer panel . Trace the heater wires (1 on each side) and disconnect . Useing an ohm meter , or beep meter (tells continuity) , test the 2 heater wires for continuiny . No continuity , replace the heater
pt # 61002046 . If continuity thru heater , then bimetal is bad (small disk clipped onto the coils , with 2 wires attached . Pt # 61005254 .
Aug 26, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerator not getting any air, (it is warm), freezer seems ok
so you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Jan 05, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
GE GSH25JFR Side by Side Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
