Question about Maytag Atlantis MAV6451 Top Load Washer
Won't agitate in delicate or hand wash
I tried running a delicate cycle and came back to find an electrical burning smell and washer humming turned it to regular cycle everything ran fine.
  • 240 Answers
Sounds like you may have a problem with the motor. These motors have two speeds, and the lower speed maybe going bad. If you are handy, the motor is really pretty easy to replace, but the motor itself is a touch costly (Maytag Number 21001950), usually around $150.00 (but you can sometimes find them on ebay for less). If you want to replace it yourself and need further help getting to it, let me know, really quite easy. Jim
Posted on Nov 15, 2007
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washer agitates but will not spin. Burning smell coming from motor
The water pump could be stuck, or broken so the pulley on the pump is not spinning, while the belt is, which gives you the burning smell. Could also mean the motor is overheating giving you the burning smell. You will have to open the back and observe whats happening while its running. Just keep your hands clear while its working.
Feb 16, 2015 | Kenmore 98702 Stacked Washer/Dryer
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
Maytag PAV2300AWW, ONLY WORKS ON REGULAR CYCLE. ON DELICATE CYCLE CLICKING NOISE LIKE SWITCH OFF AND ON AND AGITATOR WILL MOVE SLIGHTLY WHEN CLICKS. MY SON HAD IT ON A WHILE BACK ON THE DELICATE CYCLE AND...
Your timer is bad on that cycle. It is okay to use on regular cycle, but I would not use it on the delicate cycle, or will you burn up your timer. You should be home when using this, so if it does act up you can catch it.
Dec 01, 2009 | Maytag PAV2300 Top Load Washer
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Whilpool washer Model # LXR9445JQO During wash cycle the motor stopped working, became hot (you could smell it). Now the motor just hums and starts to get hot, you can't turn the agitator or basket by...
STOP trying to run the washer you will burn it up!!
You need to remove the agitater and make sure nothing is tangled around the shaft. If there isn't anything tangled you will need to do surgery on your washer. You will need to remove the back access panel and remove the lines from the water pump on the back "one going in and one coming out" pull the pump off the shaft and make sure that it spins freely. Hopefully the motor isn't burned up to bad from trying to run it!! have a GREAT day!
May 10, 2009 | Washing Machines
Washer will not agitate or spin
it looks to me u need a new motor as the one u have is burned out...this is the humming u hear....contents insurance will pay for new motor if u have one
Apr 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Atlantis MAV6451 Top Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
