Question about Husqvarna Husky 165
Husky 165 - won't do a basting stitch
Hello:
My Husky 165 will not do a basting stitch no matter how long I set the stitch length. It used to baste and then I didn't use my machine for a few months and now it won't. Can someone suggest what the problem might be?
  • Anonymous Mar 20, 2014
    baste stitch
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Posted on Nov 14, 2007
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
How do you machine baste on a brother PE 830DL I am wanting to embroider on stretch material and I was told to float the stretch material and baste it to the tear away in the hoop thanks
A basting stitch is just a matter of setting the stitch length to very long. If you want to remove the basting stitch after your project is complete, you can also loosen the top tension so the bobbin thread will pull out very easily.
Wondering if a wash-away fabric spray adhesive will work just as well.
Apr 07, 2017 | Brother Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
I want to baste and dont know how to set straight stitch and length.
To baste, set the stitch length as high as possible (zero is a non-stitch length, probably 4 or 5 on your machine is the largest stitch length). Set the stitch width to zero so there is no zig-zag.
Jan 09, 2017 | Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
How can I do basting stitch for machine embroidery?
Some machines have a built-in basting stitch. If yours doesn't have it, the closest you can get is setting the stitch length to as long as possible. To make the basting stitch easy to remove, loosen the upper tension. Then to remove the thread, just grab the bobbin thread and pull.
Jan 28, 2016 | Sewing Machines
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
Apr 12, 2011 | Elna Quilter's Dream 6003Q
I need to know how to find the basting stitch on my ex660
The basting stitch is not normally a separate stitch, just set the stitch length as long as it will go, and the same for the stitch spacing. Make sure you are not using any fancy setting or zigzag and this should be fine for basting.
Mar 14, 2009 | Sewing Machines
Sewing Machines Logo
194 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
