Question about Whirlpool 24 in. DU948PWPQ Built-in Dishwasher
Grinding noise when washing
Hi, my dishwasher had a grinding noise before and when I had someone come out to look at it there was a bunch of popsicle sticks in the pump. So now the grinding has come back and I suspect there is something in the pump. I have dismantled the filter module down just past the seal. I can't get the black thingy off to get down into the pump. How can I do that?
  • pooroo Apr 27, 2008
    There is a 1/4 inch hex head screw holding the black "thingy" Is this a right or left hand screw??? Hate to break it!!! Tried both ways but it seems to be stuborn. Help !!! Is it left or right hand thread?????
  • 423 Answers
I just saw this question. Did you get the problem solved?
FYI: the screw you are describing is a standard righty-tighty, lefty loosy thread.
Hope this helps.
Posted on Mar 28, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Grinding noise in Samsung dishwasher
Grinding noise usually is from the wash motor.
Mar 04, 2015 | Samsung DMT800RHS Dishwasher
Not washing
Hi, there is a circulation motor that has an impeller attached to it. this is called the wash motor. it is located under the sump area. this wash impeller has become damaged and, you will need to replace it asap. this is causing the grinding noise. the impeller may be stripped or, it has slipped off the shaft. replacing this damaged impeller will fix this issue.
Jul 26, 2009 | Dishwashers
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Grinding noise in dishwasher. 4 day after warranty..Can I fix it myself...Need your help... Thank You, Sandi
Hi
Grinding noise is due to a cracked impeller which can be accessed by removing the spray arm. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Dishwashers
My 10 yr old kichenaid dishwasher is making a grinding noise do y
Well a grinding noise could come from any moving part. It could be the wash arm, motor, or pump. Remove the wash arm and clean all that you can reach with a nylon brush. If that doesn't do it, call the repairman.
Mar 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Grinding Noise
Wash out the drain and filter.
May 08, 2008 | Amana 24 in. ADB3500AW Built-in Dishwasher
Maytag dishwasher mdb56000aww
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool 24 in. DU948PWPQ Built-in Dishwasher Logo
192 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
