Question about Sony KP-53HS10 TV
Sony KP-53HS10 The picture was perfect and all of a sudden the green bowed at the top and bottom of the screen, I am unable to bring it back with the auto convergence or the manual convergence. I have replaced the IC on the CG board but the problem persist, the green will not move when I try and do a manual convergence. I have seen some other post about fuses, for some similar models, I would like to know if there is anything else I should be checking.
  • 143 Answers
Re: Sony KP-53HS10
Tim when you changed this ic did you look for blown fuses check all fuses and see if you might have what is called a pico fuse
Posted on Nov 15, 2007
  • 934 Answers
Re: Sony KP-53HS10
You said in your post you replaced the IC on the CG board. I assume you mean that you replaced the STK392-020? If so did you measure the value of the 2.2k feed resistors just in front of the amp? Assuming you've done all that and everything measured fine then I would suggest a corrupt eprom located on the BM board (about 4x6 inch board that plugs onto another larger one). The complete baord is about the two hundred dollar range and one this old 4:3 aspect ratio model it's probably not worth all the hassle. It would be about a 4-6 hundred dollar repair in the shop, including parts, and to do it yourself would be nearly impossible for all the manual adjustments you would have to add back in after the repair.
You would also need to order the jig from Sony for a grid patter to follow and if you're not used to writing in hex to reset the pattern I assure you it would be a project that could last you all winter...
On the other hand, if you don't mind spending the 4-6 hundred call around and see what off the cuff estimates a shop will give you for doing the work.
Hope this helps.
Posted on Nov 13, 2007
  • 306 Answers
Re: Sony KP-53HS10
Is there a speaker near it or anything that might have a magnetic charge? Magnets really faul up a screen.
Posted on Nov 12, 2007
0 characters
3 Points
I have a Sony projection TV KP-53HS10. From one
It is most likely the convergence board. Rear projection TVs use three lights to display the image. The image is aligned via the convergence circuit. After many many hours of use the capacitors and resistors on the board lose their tolerances. It is very expensive to repair if you take into account the price for a new TV and the quality of the image you will be getting if you do have it repaired.
Mar 01, 2011 | Sony KP-53HS10 TV
Sony kp-53hs10 picture is cloudy and 3 colors at bottom of screen red blue and green
Look at attached photo--if it is what you have you have a convergence problem.
The KP-53HS10 uses two of the STK-392-020 convergence chips.
Both will need to be replaced and the set adjusted--parts cost on ebay is less than 20 dollars--repair consists of two things--getting at the parts and then replacing them--chips are soldered in so you need to be able to un solder them and solder the new ones in.
If this has helped out, rate this solution as I do this here for free.
Second picture:
Dec 18, 2009 | Sony KP-53HS10 TV
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Screen is green. audio is fine...
sounds like you have a crt bulb out better call someone out to look but it will be a little pricey
Aug 29, 2008 | Sony KP-53HS10 TV
Pink Picture
You TV missing Green color ratio to produce correct colors in picture. It might needs service and adjustments in Video section .
Aug 03, 2008 | Sony KP-53HS10 TV
Green bulb for projection tv
I found the lamps at for $146 plus ship/hand/taxes
Feb 02, 2008 | Sony KP-53HS10 TV
Sony kp-53s10
Hi: Check the horizontal output stage. Many Sony chassis have a control scr device on the emitter of the h.o.t. or the flyback may be bad. Good luck.
Jan 29, 2008 | Sony KP-53HS10 TV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
81 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
