Question about Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
Black & Decker hand held dustbuster
My B&D dustbuster seems to not be charging? Any suggestions. It is about 1 1/2 yrs. old.
Thanks for any advice you can offer.
Magi
  • Anonymous Mar 18, 2014
    12 volt black and decker dustbuster is apart. How do I put it back together again?
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
Posted on Dec 06, 2007
    New Friend:
Make sure the on/off Switch is FULLY in the "OFF" position, or it will not charge. ( The unit turns off when the switch is about 3/4 of the way to the "OFF" position)
Posted on Jul 22, 2013
  • un listed Jul 22, 2013
Need a replacement battery for chv1210 dustbuster 12v
SORRY we do not source things for people search google Google
Nov 29, 2017 | Vacuums
How old are these dustbusters
The Black & Decker DustBuster (now stylized as DUSTBUSTER) is a cordless vacuum cleaner that was introduced in January 1979.
Mark Proett and Carroll Gantz are listed as the inventors on the utility and design patents, respectively, assigned to Black & Decker for a cordless vacuum cleaner.
If you want to get some other insformation, please be more specificabout your question
Nov 08, 2015 | Vacuums
1-year old dustbuster black decker cwv1408 will not run unless I slap it on left side.
Your description would suggest either loose wire or a short in the switch. Take the unit apart and check to see that battery terminals are tightly connected.
Jan 02, 2015 | Vacuums
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Do I need to replace the battery as my dustbuster does not seem to have a lot of power and therefore does not pick up as it used to?
Yes the battery is most probably the problem. you can check is the voltage of the fully charge battery is same as what is stated on it, if not you definitely need a new battery
Mar 05, 2011 | Black & Decker 15.6 Volt DustBuster Vacuum
I need a black and decker dustbuster manual to know what kind of batteries to buy. I recently got this dustbuster at a garage sale. The charge/wall mount says it is a 9.6volt FVE9610 Type 1. Help? Joan...
I have bad news. That part is no longer available; check out the info here:
http://www.ereplacementparts.com/black-and-decker-fve9610-dustbuster-parts-c-4167_8887_8911.html
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Feb 05, 2011 | Vacuums
How long do i have to charge a dustbuster? I purchased one at a garage sale and it does not seem to be working. The owner said that it was working..
if its not working at all it has a fault that could be anywere if it is working but with little suction then the batery is no good replace the battery
Jun 25, 2010 | Black & Decker AV1200 DustBuster Handheld...
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum Logo
531 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
