Depending on the model, the limit reset is located on the back of the control panel. You might see a little red button or there could be a little hole that you can poke a toothpick in the push the reset button.
A failed element is the most likely cause, but pretty bad if used once. Check the fuse in the plug, check the power cord. Check around the back for an overheat reset button.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout.
I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
theres a reset button on the back hidden on the right side in a little whole you will need a bbq skwer you will hear a little click and it will start working again
The element will show infinite resistence if defective. Overload switch.....Do you mean High Limit T/Stat? Use your ohm meter across terminals- should read closed circuit...0 ohms. If not, push red reset button...if clicks once, is now reset and contactors will close and unit will heat. If always clicks, replace limit t/stat Like wise, check themostat--should click once for heat demand and check cicuit same as limit t/stat. May have wire burned off terminal connector at element.
I had the same problem, but I fixed mine!!!! Make sure that the part with the control panel is locked in. It you just sit it in, it won't come on. You must lock it in on the side.
