Check the Power Adapter and Outlet:
Ensure that the AC power adapter is securely connected to both your laptop and a functional power outlet.
If your laptop has an AC power indicator light, make sure it's illuminated. If not, try a different wall outlet (avoid using a power bar) .
Battery Charge Stops at 60%:
If your battery charge stops at 55%-60% and shows a "plugged in, not charging" message, it might be due to a power management setting.
Some Lenovo laptops have a feature that limits battery charging to extend battery life. To disable this:
For models with Lenovo Energy Management, Lenovo Power Manager, OneKey Optimizer, Lenovo Settings, or Lenovo Vantage:
Check if "Conservation Mode" is turned on. If so, turn it off.
If the issue persists, try updating your laptop's BIOS:
Go to the Lenovo support website, download the latest BIOS for your model, and install it.
Reboot your PC and check if the problem is resolved.
Hard Reset:
Sometimes a hard reset can help resolve charging issues:
Shut down your computer.
Remove the battery (if detachable).
Hold down the power button for 30 seconds (with the battery removed).
Reattach the battery, plug in the AC adapter, and turn on the computer. The battery should start charging .
If these steps don't solve the problem, there might be other causes.
To disable Windows 11 automatic updates, open Settings > Windows Update, and click the "Pause for 1 week" button to disable updates. You can also use Group Policy or Registry to disable automatic updates you can google your question for more info and details
#1 disconnect engine battery to disable power to SRS, then you can unplug air bag safely. If weather is cold, ground yourself to the chassis/frame to neutralize any static charge as you unplug the connector to the airbag module. #2 Sounds like you disconnected the vent door actuator, you can drive without it.
To disable the internet, you must talk to the helpline of the service provider so that they disable the internet connection and stop charging you for it.
Update will install the latest firmware on the phone. This process will delete all the data on the phone. hence, you must always backup the data before updating the device. Data includes contacts, msgs, settings, pics videos etc etc.
There should be a place to disable it. For Windows updates in XP, go to control panel, Automatic updates, and turn it off there. It can also be disabled in IE. For HP updates, there has to be an icon on the taskbar (I would think), or perhaps under "Programs" you'll find an HP support program that will allow you to disable updates. Personally, I would not disable most updates. I can agree... I hate the IE add-ons and taskbars that just take up space. Give me simple... cut the glitz and hype. However, the security updates are important. I would select a time to update when I am not using the computer. For a browser, I prefer Google Chrome. It is simple, but very flexible... thinks more like me. If Windows is user friendly, I am NOT a user! I hope this helps.
I sounds by your explanation, that the belt which drives the alternator is slipping when it gets wet. When this happens the alternator stops charging the battery, and when battery voltage drops the engine cuts out and won't start due to not having enough current to supply electrons as well as starter motor. Have the belt tension checked, as well as charging output of alternator, should fix it.
Check that camera hasn't been
set for no-flash mode.
Give the flash time to charge before pressing shutter.
Try to reset your phone by MASTER RESET(Factory reset) by referring to your manual.
If you updated the firmware for your camera, then that update can also be a reason for your flash not working. so try installing the firmware which was present when the camera was working good.
check there is any debris in the hot shoe, there is a switch on the left
that stops the pop up working when you put a external flash on.
If you have been using a speedlite or another flash on the hotshoe
lately, there is a little metal strip in the hotshoe (rail) that
disables the pop-up built-in flash. So, this little metal strip goes
down when you slide in an external flash and disable the built-in flash
by breaking an electrical contact. This little metal strip has the
occasional tendency to get stucked down after unmounting your
speedlite, which results in the behavior you are seeing. Just turn OFF
your camera and use a toohpick in the hotshoe and force very gently the
metal strip up to make the metal strip goes back to its original
position when there is no speedlite mounted on your camera. Compare
both sides in the hotshoe (rail). Turn it ON and there you go!
Hope my info solves your problem, Thanx for using fixya, Cheers.
