The error.
Netflix uses Microsoft silverlight instead of flash to stream movies etc.the default folder is in the Microsoft ....silverlight....playready folder.when errors occur sometimes delete the contents or cache as this gets corrupted.then restart netflix.the path is usually administration data ....Microsoft......silverlight ....playready but you can just search for the playready location.clear the contents of that folder and it should be good to go.check link below
http://bt.custhelp.com/app/answers/detail/a_id/46766/~/clearing-the-playready-cache-to-fix-silverlight-errors
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
