Question about Baby Trend Expedition Double Jogger
Baby Trend Double jogger
The rear right wheel is kind of wobbly and it's causing the strollr to pull to the right. When I get walking fast, it looks like it's bent. It's not bent, it just causes it to look that way. How do I tighten it or fix it?
  • Anonymous May 05, 2008
    I need to know how to tighten the back wheels.
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Posted on Apr 08, 2008
Lexus,I recently had the rear subframe out and fixed leaks in differential, I have the car jacked up and in 2nd gear I notice that the drivers side wheel has a wobble in it. Is this a wheel bearing?
No, you check a wheel bearing by grabbing the top and bottom of the tyre and try and rock in and out looking for play. Worn bearing also make a noise when you drive, a whine or a drone. Normal cause of wobble is balance weights falling off, or a bent rim. On my Lexus, I had a slight wobble in the steering wheel and it turned out the alloy rim was out of true.
Feb 11, 2017 | Lexus Cars & Trucks
Ford explorer 2011 rear axle wobbling and propeller shaft hitting the fuel tank bracket possible causes.
Sorry to say it sounds like you have a bent axle, If you mean Drive shaft when you say propeller shaft, then that's either because you also bent the driveshaft or you have u-joints that have gone bad. It sounds like a mess, Did you hit something or run over something? Rear axle don't just get bent form nothing. Has there been a grinding noise for awhile coming from the rear area? Your axle bearing or wheel hub bearing may be shot causing the wobble,
Nov 01, 2016 | Ford Cars & Trucks
Rear wheel is wobbling
I wouldn't drive it because the wheel could come off if the bearings go out, and they might. Have it towed to a shop and have a mechanic look at it. This condition is DANGEROUS.
Mar 30, 2014 | 2000 Mercury Grand Marquis
The driver rear tire wables when driving
I assume that the wobble is side to side and not up and down. The most benign cause of wheel wobble is a bent tire rim; but since you've tried another wheel and still get the wobble, the cause could be a bent housing, bad bearing, a number of things. In any case, if you don't get it fixed, a castastrophic failure is likely to happen. The rear axle is semi-floating; the axle and wheel are held on only by the pressed-on bearing and a small circlip. See a mechanic ASAP.
Jan 07, 2012 | 1994 Isuzu Rodeo
My rear right side tire is wobbling on my cheverlote cavalier?
are the lug nuts tight?
If so you may want to remove the wheel to inspect more thoroughly as that is serious - you may have a possible broken lug bolt - hard to say more without more details.
: Possible bent rim?
Loose half shaft (depending on if front or rear?)
Bearing on the spindle could be shot if on the rear..
best regards
Mar 14, 2011 | 2000 Chevrolet Cavalier
The rear tire is on tight but it wobbles and shakes the whole car when i drive it. it has good tires on it.
3 possible answers. 1 the rim is bent 2 . unbalanced tire 3. wheel bearing needs replacement
Jan 03, 2011 | 2004 Pontiac Grand Prix
I hit a hole backing out of a driveway and after i heard a noise in the front end from hitting a hole the front tire started to wobble and pull to the left, something is wrong please tell me what
This could be a few things, first try switching a rear tire to the front and see if that helps, you may have bent the rim but you would need to look at it and see is the rim is bent then look at the tie rod end to see if its bent, you could have bent the strut or lower control arm too. i would take a look at the tie rod end and see if its bent, here the thing, you say it wobbles and pulls, a tie rod end or strut or control arm will make the car pull but not wobble, a wobble would be caused by a bent rim or tire witth a bubble and this can make the car pull, tire putting the spare tire on and see if it still pulls and wobbles, if it doesnt then you know its the rim or tire, hope this helps.
Nov 10, 2010 | 1999 Buick Century
I have a new trike that may have ome shipping damage (bought at flea market) The rear axel appears to be bent. severe wheel wooble. is there some adjustment in those set screw type bolts in the center of...
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
Sep 23, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
My Baby Trend Jogger's front wheel wobbles when we get past a slow walk towards a moderate walking speed. How do I solve this problem?
check that the axel is not bent and see if the wheel on the axel fits snguly twist it side to side it may have have woren the axel hole out
Aug 30, 2010 | Baby Trend Expedition LE Jogger
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
Baby Trend Expedition Double Jogger Logo
404 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
