Hi Anon,
The 0x800106ba error may occur after Windows Defender is updated due to the computer's inability to update the Windows Defender firewall. It may not have applicable permissions needed for the update, or it may not have the files necessary for updating itself.
The Fix
Set Windows Defender to Automatic - You can set the Windows Defender service to Automatic, Disabled or Manual. Setting it to automatic might solve the problem. Follow these steps:
Uninstall and reinstall Windows Defender - If the first procedure did not help resolve the problem, try un-installing and then reinstalling Windows Defender. Due to the fact that Windows Defender is a Windows component, we will use AppWiz to un-install it from the computer. Follow these steps:
Let me know how you go!
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
