Question about Canon PIXMA MP830 All-In-One InkJet Printer
What is error code 6A00?
Error message unlock scanner lock which I did but same error message appears.
SOURCE:
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
komguy
  • 2306 Answers
SOURCE: Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Posted on Jan 28, 2010
pineworks
  • 4345 Answers
SOURCE: error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
Posted on Apr 25, 2010
matt800
  • 241 Answers
SOURCE: 6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
Posted on Nov 22, 2012
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Error code 6A00
I HAVE A CANON MP600 ALL IN ONE PRINTER. SCANNER etc., AND I HAVE AN ERROR CODE OF 6A00 COME UP! both green and amber lights flashing and will not allow me to print... can you please help
Aug 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
The offending item needs to be removed or the purge unit needs replacement.
Also clean the purge unit out make sure all is clean
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
On printer screen it is showing Error 6A00 and error code. Whats does this mean and how can I fix it
In my IP 3000 during a print suddenly on the 3rd page, a big "crunch" sound. Paper was jammed - error 5100 or smthg, and managed to remove the paper... but then error 6A00 came up. I found this post and was saved. Manually moved the print head left and right, turned the printer on/off. Still the same error. Then I noticed a piece of torn paper lodged inside. Removed that, got inky fingers, and finally got printer in working condition.
Try to clean any foreign object inside.May be it can help you.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Locked In Copy Mode--Error Message: 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Sep 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
90 people viewed this question
Clive
Clive
old marine
old marine
Ekse
