Home | Motorola | RAZR V3 | My cell phone screen don...
Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
My cell phone screen dont work ...help
By bella15 on Nov 12, 2007
my phone works just the screen dont work it gose on but its a blank screen..i get calls i can make calls. i just dont know what number iam putting in..i have a razor v3 and on the back i know i have alittle water damage but it works just not the screen..help me
Same Problem
May 21, 2009
-   a water balloon burst in my bag and my phone was at the bottom,and now my screens just blank!! :| how ccan i fix it???????? -   florenceBOO
May 12, 2009
-   same problem u guys mentioned above..i mean not able to see contact on the screen ..but i m getting call n can make call too..it's motorala phonee -   Guest
Apr 29, 2009
-   i have no water damage, but i let my battery run down constantly. is that the reason? -   Guest
Apr 27, 2009
-   My phone lights up on the keyboard but the screen doesnt-   hoodboyjones
Apr 27, 2009
-   My phone screen doesn't appear when I open it. The number pad (keyboard) lights up but the screen wont even show up-   hoodboyjones
Best Solution
posted on Mar 11, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
**** it worked :)
this is like the first time me fixin a phone :)
Solution #2
posted on Sep 20, 2008
Very Helpful)
dobson991
Rank: Apprentice
Rating: 96%, 8 votes
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 25, 2008
Very Helpful)
jainm6
Rank: Apprentice
Rating: 96%, 10 votes
Hey I had the same problem with my w300i ....But to add to another hell i could not even make calls ...even though I dial a number without seeing ...the problem i Had was that I could not listen to the caller...I could do it using the speaker though....just wanna know what the hell wnet roung with hte cell.But then I just didi not try to do anything with it ...Ohhh then after around 8-9 days suddenly One morning I got up and just toook the phone with me to the office.On reaching I found that evrything was ok with the Phone......The display and all was as perfect as it could be...But one thing....I still cannot hear the caller though he can listen to me....But I can do that very well with a Cell Phone on speaker mode...Some technician suggest a solution pleaseeeeeeeeeee.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jan 07, 2008
Very Helpful)
lmend
Rank: Apprentice
Rating: 96%, 6 votes
is there any way that you can take pictures of how to fix it and post them so that I can see what to do with my screen?
Was this helpful?
Yes
No
Solution #5
posted on Jul 13, 2008
Very Helpful)
bubbah
Rank: Apprentice
opened torx screws as above, found connector after separation of bezel, careful not to lose screws or rubber plugs (reglue with rubber cement) or the keys (which have a direction to them)...connector for camera is easy (goes to camera, duh!) ...other (white) one is for screen(s) ...pushed it in, screens back ...had to open it again 'cuz it came loose again ...cleaned with RadioShack Control/Contact Cleaner & Lubricant #64-4315 ...pushed it back in very well until I felt it "seated" ...all is fine now...lost 1 of the rubber bumpers ...bought on ebay or from cnn.cn ...all this is for RazrV3 fone... look here for guides: http://incipiotech.com/moto/motorola_v3_housing_guide.PDF and also here: http://www.cellexcompany.com/install/v3_install.pdf ...I had torx drivers and open tool ...cannot be done without torx driver ...can use edge of credit card instead of open tool ...overall VERY EASY to do for even silly me who dropped fone on bathroom floor!!
Was this helpful?
Yes
No
Solution #6
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if done carefully it will work....one tip: be gentle.........thank you so much
Solution #7
posted on Nov 22, 2007
Helpful)
ez407
Rank: Wiz  Motorola Expert
Rating: 85%, 39 votes
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #8
posted on Jun 24, 2008
Helpful)
MYPHONEWORKS
Rank: Apprentice
Rating: 83%, 2 votes
IT Worked for my motorola krazer
Was this helpful?
Yes
No
Solution #9
posted on May 07, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Right on the money EZ407 and to add to what you said it may also help to insert a small piece of paper under the keypad peice cause this will help it to stay connected tight. Thanks for the heads up I was just about to buy a new phone glad I stopped by.
Solution #10
posted on May 04, 2008
Somewhat Helpful)
flyaway7
Rank: Apprentice
Rating: 70%, 1 votes
heya there usd
Was this helpful?
Yes
No
Solution #11
posted on Mar 04, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks a ton basically i gave great advice, U might as well said"Do something to something in ur phone" Be less specific if possible? thanks?
Solution #12
posted on Aug 26, 2009
Very Helpful)
riah13
Rank: Apprentice
Rating: 100%, 1 votes
A friend, who studied chemistry in college, told me to try putting my phone with some salt to dry up my 8 month old slobber. So I put my phone in a bag with salt [regular table salt] over night and it worked like a charm! It dried out my phone so that I didn't have to purchase a new one. I have insurance on the phone, but now I don't have to lose any of my data or pictures. I'm now a firm believer in sending all your pictures to email and writing down all your contacts so that when your phone does die your not without those things!
Was this helpful?
Yes
No
Solution #13
posted on May 03, 2009
Somewhat Helpful)
AWARAPAN
Rank: Master
Rating: 76%, 20 votes
Try the link . . . http://www.Motorola.com/Razav3
For find best solution.
Was this helpful?
Yes
No
Solution #14
posted on May 02, 2009
Somewhat Helpful)
eiarp
Rank: Master
Rating: 86%, 11 votes
Hi Friends,
Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3 is hardware problem. Such as won't charge, black screen etcFor solution of these hardware problem just click here.
For any other problem of Motorola RAZR V3 like software problem or other just click here.
Was this helpful?
Yes
No
Solution #15
posted on Nov 20, 2008
Not Rated)
herricknell
Rank: Apprentice
Rating: 0%, 0 votes
Hello can anyone help me I have two razor cell phone one has a black screen I'm able to make calls and recieve calls. Then I have another razor that has two little boxes looks like two computer try to communicating it's right next to the bars at the top left corner of the screen.
How do I clear the two boxes and is the black screen repairable?
Thanks Nell
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
I can not send pictures with the motorola v3.
Answer
my motorola v3 hang when i use to txting what should i do
Answer
I am trying to pair my phone with my MOtorola H12 but asking for a pass key. i forgot my pass key.... (More)
Answer
trying to configure v3 to boost mobile isit possible
Answer
My Motorola RAZR V3, which is 3 weeks old, front and inside screen turns off, but the phone is still... (More)
45 Other Users Have The Same Problem - Continued
Comment by Pudinbud, posted on Apr 19, 2009
The other day I dropped my phone in a glass of water. This was also the first time ive ever done it, so I just dried the batter and phone off and turned it back on. It worked a little while then it started doing crazy stuff. I asked my brother and he told me to take it apart and let it dry a little bit, and after 6 hours I turned it back on and it worked fine, but then it started screwing up again so I turned it back off, and then like an hour later I went to turn it back on and the buttons lite up and it made noise but my screen showed blank....So im going to let it sit for a few day, Do you think my screen will work again.
Comment by Guest, posted on Apr 07, 2009
mine worked fine till i put my memory card in it and while working on my car got a little bit of gas on it but not enough to actually hurt in cuz it never entered the phone itself
but what it does is while texting the phone would shoot to a blank screen and used to be fixed by closing and reopening the phone and sometimes readjusting the memory card but now it doesnt show anything at all anymore just the backlighting
i can still recieve and make calls
as well as i can recieve texts but i just cant see them
its irritating this is the 2nd razor thats done this to me
Comment by Guest, posted on Mar 22, 2009
I dropped my phone and the screen works sometimes but other times not, i would like to fix it because i love the phone
Comment by twonscott, posted on Mar 13, 2009
hi i have a MOTOROKR™ Z6m slide up phone and it comes on half way which it only displays the Motorola logo. My phone has no water damage please help me
Comment by zsimons, posted on Mar 09, 2009
same here, i have a verizon lg. It went through the wash and now the screan doesn't work. Im able to do everything else. The only thing i can think of is just getting a new phone. I'v tried setting it by my fireplace, and even taking it appart, but it just will not budge.
Comment by Guest, posted on Mar 07, 2009
my cell phone screen dont work ...help
Comment by Guest, posted on Mar 05, 2009
My phone's screen, both front and main, are completly dark but its not turned off. Its almost imposible to see anything on my main screen and its extreamly annoing. PLEASE HELP
Comment by Guest, posted on Feb 07, 2009
I have a pebbl phone and I can still make calls and I can recieve calls but the screen remains blank.
Comment by Piluvm, posted on Jan 26, 2009
I have the same problem, one day it was fine, the next a blank screen. I do not have water damage, however one of the screws on the side fell off, and it was put back. Still not able to see who is calling or who I am calling, cannot receive or send text messages. Help!
RAlonzo
Comment by Guest, posted on Jan 23, 2009
I have the same problem but my phone is LG-VX5400. Everything works except my screen is blank.
I have a LG-VX5400. Eveything works except my screen is blank. Can you help me?
same thing exactly as hers except i have a pebl!
Comment by Guest, posted on Jan 15, 2009
i can see the light of the keypad light up, but the screen just stays black.
Comment by curtice10, posted on Jan 15, 2009
my screen doesnt work it was in my pocket while i was playing rock band 2 i was playing painkiller on experts and since then my phone screen wont go on its not a white blank its not turning on
the sceen dont work
Comment by Guest, posted on Dec 22, 2008
the screen comes and goes i can see part of the time and the other i cant does anyone know what is wrong with this thing
Comment by emmyirock, posted on Dec 20, 2008
i have a krazer k1 and its screen is just black it happens a lot i cant c my txts or c who's calling i need help on how to fix it!! plZ
Comment by Guest, posted on Nov 26, 2008
my phone screen turns on but just no display... its just blue
Comment by duhsheloves, posted on Sep 20, 2008
i havee the same problem..my phone died one time and i charged it to turn it on, any my screen was blank for a couple of days, and then it came back, and now its back to the blank screen and has been for about a week and i keep gettings texts..that i can't read! it bothers me soo much
Comment by bluek9, posted on Sep 20, 2008
black screen when turning on the phone
Comment by Guest, posted on Sep 20, 2008
helpp!
Comment by label524, posted on Sep 16, 2008
i have the chocolate ( original ) and it is doing the same. I WANT TO READ MY TEXT MESSAGES!!!!
Comment by Guest, posted on Aug 07, 2008
i have the same problem when i turn on my phone it is a black screen and i can't see anything.
Comment by veebee3, posted on Aug 07, 2008
My Motorola v3 works just fine except the screen is just black doesn't show anything...I can still text and call people but the screen is blank and i don't know if i'm dialing the right number...it does have a little water damage but I don't think that has anything to do with it..HELP ME!
Comment by princess_bir, posted on Aug 03, 2008
My phone works to make calls, screen is white. I think it may have something to do with the cable inside, because prior to my screen staying completely white, it would work if I flipped it open just right. My screen seems to be the first to go, even with other types of phones.
Comment by Guest, posted on Jul 27, 2008
same problem, the card must have gotten dirty or broke.
Comment by Guest, posted on Mar 03, 2008
blank screen... trying to shut down and log on again
Comment by dottied, posted on Jan 07, 2008
My phone just started the same thing this past weekend, It was working fine the night beofre and the next day I turned it on and my screen was blank, I can make calls and get them, but I have no idea whos calling or who I am calling.
Comment by Guest, posted on Dec 04, 2007
Turned my phone off for a second and try to turn it back on, the lights in my keyboard work and sound but my screen wont turn on.
Comment by Cassi, posted on Nov 23, 2007
i have know idea what to do, it's like i'm blind. i feel pretty horrible because it is "just a phone". however it's a phone with a blank screen, nothing it's pretty much uesless and i have absolutely know money to buy anouther! HELP!!!
Comment by dilling, posted on Nov 21, 2007
I have the same problem off and on.
Comment by Guest, posted on Nov 21, 2007
Comment by Andriy, posted on Nov 21, 2007
The same problem
We all have the same problem, does anyone have a solution??
Comment by qwewaefsev, posted on Nov 20, 2007
Comment by Guest, posted on Nov 13, 2007
Same problem...sound works, can make calls but the screen remains white.
SAME EXACT PROBLEM
V3 Razr.... the lights still go on and off, as well as the noises that usually accompany any action...but nothing showing up on screen!
i can call people and talk, but still a blank screen!
I have the exact same problem! My issue started today, 11/12/07. I need to access my phone book, which i did not save to my sim card! What can I do?
Comment by calciodave, posted on Nov 12, 2007
I have the same exact problem and it started yesterday.
Is this fixable?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola RAZR V3 Cellular...:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 728
Experience: Having problems myself and learning from my mistakes . Plus looking up information on the web.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
