Sharp MX-2700N Color Copier Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Server unavailable error
Scanning document get a Server unavailable error
unkl foddy
Level 2:
Scholar:
  • Sharp Expert 120 Answers
  • Posted on Jul 09, 2009
unkl foddy
Sharp Expert
Level 2:
Scholar:
Answers
120
Questions
Helped
116553
Points
169
Ah, the dreaded CE-00 and CE-02. This is a networking problem!!
It means the IP address stored in the copier for the computer you're trying to scan to is old and stale!!! That workstation got its IP refreshed by DHCP and your copier has been left in the dust!
To refresh the workstation's scan profile information in the copier either:
1) Reboot the workstation, or
2) Find the Network Scanner Tool icon in your tray, right-click on it, find Automatic Profile Update, and click on Update Now.
Also check the webpage and make sure that if you're using DNS for name resolution that you have the correct and working DNS IP's!!
1helpful
2answers
Unknown error
Consider the following scenario:
1. You install an antivirus scanner for Microsoft SharePoint Server 2013 for scanning documents.
2. The antivirus scanner is unavailable for some reason, or it times out during a scan.
3. Your document is corrupted.
As a temporary workaround, if you need to access to infected file immediately, the SharePoint administrator can enable the Allow users to download infected documents option in the Central Administration portal.
Also you could try to open the file with the help of Open Office or recover Word file here: https://www.docxrepairtoolbox.com/
3helpful
Xerox scanning error 027-516:server connection error in smb
This means that your machine cannot connect to the network share to which it is supposed to write the scanned documents.
There may be several causes:
- if it worked before, perhaps the server or computer with shared folder to which the Xerox unit is configured to write files is unavailable/switched off, or the shared folder is not shared anymore or has changed security permissions, preventing the Xerox from writing, or the share name has changed
- if it never worked, perhaps the Xerox needs configuring prior to use (how it should deliver the faxes, via network share or email). Refer to it's manual on how to configure scan delivery.
Error when scanning
Hi Liz
Looking at that message I get the impression that the printer is not actually scanning but trying to 'import' from a non-existent camera card.
You don't normally get an import message when scanning.
The destination full or read only part is a puzzle but could indicate that it is also trying to copy back to that non-existent card.
I think your best option is to use Canon's web site and look at the support section. They may well have an on-line chat service in your area that can help you sort it out.
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
HP J5780 - Using scanner with print server
no, print server is just that, print server is only good for printing. I don't know if there are a device you can use for all-in -one office machine. I am looking for one myself.
1helpful
Server-error-service-unavailable on my hp printer
See this link, I had the same problem and it fixed mine.
http://slayo.com/hp-printers-mac-os-server-error-service-unavailable-or-error-1282-message-when-adding-a-printer-in-mac-os-x.html
13helpful
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
3helpful
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
