Question about Amana DLE330RAW Electric Dryer
Dryer What is the part that makes my dryer start when i close the door?
  • 833 Answers
Tiff...there is a switch which indicates that the door is open. Most units require that you push the start button on the timer panel to start/restart. You must have time set on the timer to direct the dryer to work.
Posted on Dec 21, 2007
Have ptdn600emwt dryer when pressing start button makes noise but does not run
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Feb 27, 2015 | GE PTDN600EMWT Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Whirlpool Dryers Model LEQ9508LWD does not start problem I used to be able to start it by wegling conection of the dryer load door and dryer. now it stoped completly
It sounds to me you could have a faulty door micro switch or the door is not aligned properly. When you open & close door the switch should operate so the drum stops when you take things out of dryer.
There will be a little plastic pillar on the door which presses the switch when door closed. Make sure the door isn't warped.
Nov 06, 2010 | Dryers
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer won't start
Try 2 things to see what has happened.
1st listen for a click from the door switch just as the door opens or closes. (No click = no start)
2nd reach in and rotate the drum by hand just a little bit making sure you hear the motor also turn. Then try to restart the dryer.
If rotating the drum enabled you to start the dryer the motor switch is sticking.
Feb 25, 2010 | Dryers
Dryer won't start
Make sure door switch is making electrical contact when door is closed. Check thermostat.  If it has failed in open position the dryer will not start.
Jun 03, 2009 | Dryers
Won't start - 3 beeps when Start button pushed
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 31, 2009 | Kenmore Dryers
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Amana DLE330RAW Electric Dryer Logo
70 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
