Replaceing thrmostate,radiator,heater valve,water pump,heater core and flushing the system
There are two hoses going to the heater radiator, hot coolant circulates through it , one of the hoses has a valve or tap to close or open the hot coolant to the heater radiator, make sure this valve or tap is not frozen shut.
Don't know this van specifically, but some things to check, make sure cabin filter is replaced or clean, you didn't say if the blower itself works, if not, correct or replace. Check the hoses going to the heater core, if hot water is flowing thru the core, both hoses should be hot. Check the heater controls to make sure doors in the system are opening closing as they should, you may just be drawing in cold air and not going thru the heater core.
