Question about Canon PIXMA iP5000 InkJet Photo Printer
Mutiple lines on right side of photo
On a 5x7 print on the right side, 1 1/2 inch to the left there are zig zag lines red, green, wide blue, green, red, then about 1/2 inch a white line.
    Sergeant:
    Champion:
  • 306 Answers
Try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Posted on Nov 12, 2007
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
I need to know how to do the blind stitch hem
here is a link to great info on sewing.about.com which explains this technique with images, http://sewing.about.com/od/techniques/ss/machineblindsti.htm
In brief, you need to fold the fabric to be hemmed into a Z shape with the wrong side hem edge at the bottom of the Z.
The Blind stitch is either three straight stitches then a wide zig zag which swings to the left and catches a little bit of the folded edge, or three small zig zags, then one wide zig zag to the left to catch one stitch into the folded edge. The zig zag style has a little more stretch in it so works good on jerseys and knits.
tally_girl_0.gif You need to use the blind hemming foot which helps you to line up the folded edge and keep it at a constant distance from the needle. It will look like this.
tally_girl_53.jpg Turn the little silver screw to move the white plastic guide left or right until you've got just a smidgen of fabric being stitched by the left wide stitch. Always do a practice sample first to get the stitching and guide set right. On most machines you can vary the width of the big zig by adjusting the stitch width dial a little.
You need to adjust the blind hemming foot guide so that the needle is just catching a tiny amount of your folded fabric because this is the stitch which shows on the right side of the fabric when you unfold the Z. So forget trying to hem satin or expensive fabrics this way, a hand sewn stitch will give a much better finish.
Blind hemming works best on a hem which is continuously straight on the same grain line, its not great for a curved hem. So if you've got a tiered skirt or the frill on a bed valance, it is fine as the fabric edge to be hemmed will be a continuous straight length. You can use it on a slightly curved hem for jerseys as the fabric has more give, and patterns will help to disguise the stitching too.
I hope that this helps you to sew your blind hem, 4 thumbs up if so.
Jul 19, 2011 | Brother LS2020 Sewing Machine
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Canon PIXMA iP5000 InkJet Photo Printer Logo
146 people viewed this question
old marine
old marine
