SOURCE: how do i turn on the wireless on a satellite
If you have built in wireless look on the fn there is and icon on the keys hold down the shift key and fn and a lite should lite up if you have an external card and it is not working go to start program ,my computer right click on it and click on manage ,when it opens up click on service and scrowl down until you see wireless zero configuration click on it and start service your wifi should now be active. good luck
SOURCE: i brought a new toshiba satellite pro L450/L450D
Return it to the store and let them fix or exchange. Sounds like it was a demo unit that they set a password on.
SOURCE: hi i have a toshiba
This is a security password set in the BIOS. You will need this password to by pass this screen. If you got this pc from someone, you should contact them and request password or do a complete reinstall of the os and loss all data.
Good Luck
C2Solutions
SOURCE: TOSHIBA SATELLITE L450D-13X WILL NOT BOOT UP AFTER
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
