Question about Zanussi WJS1265W Front Load Washer/Dryer
E10 Error Code
How do you unclog the filters on the water inlet line?
  • 77kate77 Apr 12, 2008
    WASHING MACHINE STOPS EVERY TEN MINUTES,STARTS BEEPING AND READS E10.IT BEEPS UNTIL I PRESS START THE IT CARRIES ON WITH THE SAME CYCLE.
  • blonde007 Aug 03, 2008
    I have tried reading the book just want to use the dryer, it starts and stops with the E10 error, then i press start again, but never dries or gets hot, Please help i have washing everywhere.
WASHING MACHINE READS E 40 WAHTS THE PROBLEM?
Posted on Oct 09, 2008
The filter is behind the square panel - on the right below the loading door. Push it to open the cover and unscrew the filter, some water may come out when you unscrew it. unclog the filter and screw it back in.
Posted on Sep 02, 2008
Simpson front load washing Machine ..Coming up with error code "E10"
E10 relates to inlet water supply not being adequate. Please check kinked inlet hoses, inlet water filter blocked, insufficient or no water is getting is getting to the machine.
Jul 22, 2016 | Simpson Washing Machines
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
Washing machine showing error e10 ??
E10 is an inlet error, or not filling water properly.
Firstly, check the inlet filter (situated on the machine, where the inlet hose turn into)
Then open the machine and check the Inlet Valve (You can attach power to the 2 points to see if the solenoid opens or not)
Good luck :-) - J.Q
Feb 16, 2011 | Zanussi Washing Machines
I am getting E10 error code, there is no water going into washer.
Hi
Error E10 in Frigidaire washer means Long Fill. It means that the washer is taking a longer time to fill; it may be due to low water pressure, due to faulty pressure switch or due to faulty water inlet valve. Please try and clean the inlet filter screen. If this doesn't resolve your issue then check the connections at Water inlet valve. Make sure the connections at the fill valve are firm and check the continuity using multimeter. To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove. Next remove the two screws on the inlet housing. Now, pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. Hope this helps... Please post back if you need more information.
Daniel
Feb 11, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error E10
Hi
Error code e10 means Problems with water inlet or during drain cycle. To resolve the error take the cold water off the inlet tube to the washing machine. Now turn back the water back on. Also, check for filter screen at inlet valve, remove it and clean. If this doesn't work then the door is not latched properly. If this doesn't resolve the issue then you would need to replace the water valve on your machine. Hope this helps...
Please post back for any further assistance.
Daniel
Aug 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidare galllery series washer when i wash sometimes it wont spin and it says E10
Hello, The E10 error code indicates there is no cold water coming into the machine, either this is because the inlet valve is bad or there is a kink in the cold water line or a blockage in the filter screen where the cold hose hooks up to the machine or one of the kids turned the cold water off at the back of the machine :) Either way you should check everything I have listed, If you can't find a blockage replace the inlet valve. If you have any questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 09, 2009 | Frigidaire GLTF2940ES Front Load Washer
My washer is showing a code
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Drying
The E10 error code means - not filling water.
The problem could be because of clogged filters on the water inlet line or a malfunction inlet valve.
Also there is still some water inside accumulated so please do check the filter for blockages.To avoid other errors check the outlet valve and the filter as a precaution.
Good luck with the machine.Please do rate my solution.Also do post comments for further help if needed.
Apr 11, 2009 | Washing Machines
WHAT DOES ERROR CODE 10 MEAN/FOR FRIDGIDARE FT.load washer
The E10 error indicates a long fill error, meaning the machine thinks it took to long to fill with water.
Recommend you check that the drain tube is not stuck too far into the stand pipe possibly causing a siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow. You can hook the drain hose off, force water through it with a water hose, unclog the stinky mess and hook it back up again and work it.. that would do it...
Dec 24, 2008 | Frigidaire ATF6000ES Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
150 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
