Dlink 2100 ap
I have (2) dlink 2100 ap's and a dlink wbr2310 router, I had my network set up with one ap and the second ap as a repeater for 2 years.
One ap crashed so ordered another, now when set in repeater mode it reboots every 10-15 seconds not allowing access to the internet.
Have all up to date firmware???????
  • 42 Answers
If you default the unit, does it still reboot?
If so, it looks like the unit is faultly.
If not, you might have a IP conflict, or channel problem. Check the two units are on the same channel, but have differant IP address.
Posted on May 09, 2008
Need to re-set my ssid network name to re-secure my wireless network
Some support information for your router can be found at dlink site:
type wbr and select 2310,
Product info at this site contains manual:
Choose Support Resources tab and then select whether or not you have RevB (it will guide you how you can tell).
You can then download the Product Manual. In the non-RevB manual, what to do with SSID is described on p25, showing where in the set-up interface to enter it. The RevB manual will likely be similar, depending on your exact model.
If you don't know how to access the device's settings, send back a comment and I will assist you further.
Sep 13, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address ( When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Wbr 2310?
check wther your wireless in on and even check that on router mac filtering is on,problm mite b your laptop is not getting detected by your router,jus check wther both are on,
Mar 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
Mar 15, 2009 | D-Link Computers & Internet
Can't connect to internet wired or wireless with wbr-2310
Disable the IPV6 and use the IPV4 then try accessing the configuration page of the router and configure the Internet Settings
Jan 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
repeater, as in a link up for wireless node to node communications?
check your computer's warranty here FREE
Feb 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Connecting to wireless network
Offhand, I am getting the impression that either way (static or auto), the AP is the one responsible for disconnecting or refusing you. One reason is that you do not have permission to join the network or there is a security key that you need to be able to access.
A couple of clarifying queries pls:
1. Which configuration utility are you using for the G630, D-Links or Windows built-in?
2. Which security method is the "sons dlink 1310 wpa network" using WEP, WPA or MAC filter?
3. Have you tried different hardware configuration/settings for the 630 such as Auto Power Save, Power Management, Authentication Algorithm, Passive Scan Dwell Time, others?
4. Can you access the webbased interface config utility of the 1310 router?
Pls post back and then we can start figuring things out.
Good luck and kind regards.
Oct 12, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
