Question about Mitsubishi WD-57732 Projection Television
TV flickers My TV flickers or blinks while watching cable. I have checked connections and they are fine. I have watched a dvd and over the air hd antenna channels and both work fine. when i switch back over to cable, i get the blinking again. I assume I just need to replace the cable box. Is this correct?Right now Im running HDMI cables to the reciever and then from reciever to the TV. Same with my dvd player. Again, no problems with the dvd player. I then changed my connections an ran the hdmi directly from the cable box to the tv to see if my reciever was the problem. nope. it still blinks. Please help.
  • flickersick May 04, 2008
    i also have a wd-57732 that flickers, picture freezes, or the screen goes blank sometimes blue, yellow, etc. it's never the same color.during all of these problems the sound is fine. i got a new cable box with hdmi connections and it still has the same problems. it also does it when watching a dvd so i know it is the tv. i've had the repairman fix the airflow problem which took him like 30 minutes. he soldered wires at the thermo sensor. he has come out twice but it would never flicker while he's here, so we still do not have a fix to the flickering problem
TVtechmaniac
  • 140 Answers
SOURCE: Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Posted on Aug 25, 2007
  • 1153 Answers
SOURCE: No High-Def via monolink(HDMI) connection
Troubleshoot first by self diagnosis
Posted on Dec 16, 2007
SOURCE: akai lct42z6tm
Thanks for the suggestions! I replaced the capcitors and now the TV woeks like a champ!
Posted on Nov 05, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
  • 108 Answers
SOURCE: No sound on NON HD channels
Check menu on tv and see if the audio input has any other settings. May have different options for sound processing.
Posted on Jan 06, 2009
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
Feb 17, 2014 | LG 32LC7D Television
HOW TO STOP NON CABLE TV FROM FLICKERING
Get a better antenna or if possible a outside one--set can only deal with the quality of signal that it gets.
Dec 21, 2012 | Philips Televison & Video
Here's my setup: 46"Panasonic Viera
I'd call the cable company, it sounds like you have an issue with the cable box.
Feb 22, 2011 | Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Tv antenna
hiya
the antenna is normally on the roof. then a cable runs from the aerial to the tv
Feb 26, 2009 | Hyundai ImageQuest PD421 42 in. HD-Ready...
Plasma flicker
G'day mate,
A good HD antenna and proper orientation should do a lot of help. In the USA, a website guide HDTV owners to properly identity a suitable antenna and orientation. Check out:
http://antennaweb.org/
A similar website may be available in Australia.
If not, what you would want to do is to point the HD antenna to your source of Free To Air (FTA) broadcast.
Cheers!
Mar 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Mitsubishi WD-57732 Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
