Question about Mach Speed Trio Portable MP3 Player
Rio Carbon Pearl mp3 won't charge
My son let the battery run down pretty far on his Rio and now it just powers down when you try to turn it on. It won't charge. Just is blank when you plug in the charger - it used to show that it was charging. We are Rio lovers and hate to part with our players. We tried to reset while plugged into the charger, but nothing happens.
  • 1 more comment
  • Anonymous Sep 08, 2008
    its always charged and never turns on its just stuck on the search screen ive tried every thing and nothing seems to work what do i do
  • Anonymous Oct 11, 2008
    won't turn on
  • whiskeybo Nov 04, 2008
    my zune wont charge up.
Yeap i had the same problem that you do. Try to turn on your device and plug it in to the USB. Leave it for 5 minutes then unplug the device from the USB. It should work. ayt, peace!
Posted on Nov 15, 2008
Tr y to get a new battery. but it is tricky to get the old one out so take it to a store that deal with it.
Posted on Dec 20, 2007
How do I access the EQ section on my Rio Carbon Pearl 5 gig to change the equalizer settings?
i found the following solution:
1 Press MENU.
2 Select Settings.
3 Select Equalizer.
For more specific information follow the following link, its a manual. It answers you question on page 31.
Good luck
Dec 21, 2008 | Rio Carbon MP3 Player
Pearl rio carbon mp3 player 5gig
The microdrive is probably broken. Some people have claimed that if you give the sides a sharp tap then it has worked again but if this doesn't work then you probably require a new player. I have managed to replace the microdrive with a CF card in my Rio carbon, this has worked for many people may not work for you (you can read this: Replace broken hard drive with CF card if you want to try)
Hope this helps,
Oct 31, 2008 | Rio Carbon MP3 Player
Rio Carbon Screen is Frozen...
only thing you can do is let the battery go dead and hope that it will come on properly, you can also try pluggin it into usb, but your probably alreay tried that.
Sep 22, 2008 | Rio Carbon MP3 Player
Rio Carbon 5 GB: Battery loses power fast when player is turned off
The battery is not normally something that wears out on a Rio Carbon but if it used and charged wrong then it can either be conditioned to a shorter time or wrecked. Because it goes flat when turned off but keeps charge when on makes me slightly confused but anyway... I would advise charging it up fully and then flatten it fully - just leave it playing while you're out or something. Do this a few times and this may solve your problem. This will put maximum charge into your battery and it might solve your problem. If not then try taking the back off and look for a short circuit or obvious hardware fault.
Hope this helps,
Jul 29, 2008 | Rio Carbon MP3 Player
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
May 22, 2008 | Rio Carbon MP3 Player
EIO Carbon Pearl 5gb
Go to this part of the Rio website, and get the Plays for sure firmware update - even if you don't transfer any WMA files, this will help you get around the Windows Media Player 11 compatibility issue:
(WARNING: make sure the player is fully charged before doing this, or your player will be permanently lost)
Mar 19, 2008 | Rio Carbon MP3 Player
No content message???
Perform a firmware upgrade as instructed on the rio website - it will wipe everything clean. Make sure the player is fully charged or this upgrade will kill the player.
Oct 29, 2007 | Rio Carbon MP3 Player
Rio will not turn on
Mine JUST did that and after a while I pressed in the emergency start button on the top in the little hole.
Sep 17, 2007 | Rio Carbon MP3 Player
I broke the power button
Your power button may have come off inside the player, so you'll have to open it and resolder. Also test your battery voltage if its got a low voltage you'll have to rejuvenate it.
Jun 01, 2006 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Mach Speed Trio Portable MP3 Player Logo
378 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
