Home | HP | Digital Projector Vp6120 Multimedia Pro... | Change the lamp/ did...
HP Digital Projector Vp6120 Multimedia Projector
Problem for HP Digital Projector Vp6120 Multimedia Projector
Change the lamp/ didnt help, lamp indicator is on
By Paul Aladin on Nov 12, 2007
The customer left the HP 6120 beacuse it didnt start, i saw that the lamp error indicator lighted, i can start the projektor and all the fans starts up, i ordered a new lamp and replaced it, but after a couple of seconds the lamperror led indicator shows red.
Same Problem
Mar 22, 2009
-   HP Vp6120 with same problem others are having. Light goes on for about half a minute, gets logo screen then lamp goes out and solid red lamp light on top of unit. No luck with trying fix to unplug two back fans. Don't want to buy new lamp if it is ballast. Any way to reset lamp without projector running? Thanks-   dpcward
Apr 29, 2008
-   how do you reset the lamp timer?-   Craigwhite
Mar 08, 2008
-   My old bulb blew so i replaced it with a new one. I turned the projector on and it works during the ten second startup screen during the startup screen the overheating light started to flash and 2 seconds after the startup screen goes away and the blue screen shows up the projector shuts down. I have tried all kinds of stuff and im clueless on what to do.-   Warndorf
Best Solution
posted on Feb 06, 2009
Very Helpful)
senatore412
Rank: Apprentice
Rating: 100%, 1 votes
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jack-
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 26, 2008
Not Rated)
Marrie
Rank: Guru
Rating: 86%, 447 votes
Hi there
Did you reset the lamp timer ?
If you have and the problem still occurs , you should replace the Ballast ( lamp's powersupply )
Was this helpful?
Yes
No
Popular Solutions for HP Digital Projector Vp6120
Questions and Unsolved Problems for HP Digital Projector Vp6120
Do you recommend HP Digital Projector Vp6120 Multimedia Projector?
Answer
Answer
hp vp6120 finds video but does not find laptop Have extended image onto hp but is not finding any... (More)
Answer
The red "wrench" is lit on top. The blue power light goes off. Is it the bulb?
Answer
seems i have the same problem with my hp vp6120 - lamp replaced (i have tried 3 spares so confident... (More)
Answer
i'm having a problem finding a replacement bulb for my HP vp6120. Philips lamp, type #UHP 250W,... (More)
Answer
hp 6120 cant seem to get rid of the red /blue or mauve colours.we have tried to adjust to either end... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Digital Projector Vp6120...:
Top Multimedia Projector Experts
Rank: Guru Guru
Solutions: 1178
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Multimedia Projector Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
