Things replaced - fuel pump X2 and Engine Crankshaft Position Sensor code came up for that swapped the relay for the horn with fuel relay same type and part # new battery still no change engine turns over but doesnt start if it decides to start it may run to the end of the block or little longer the while in gear stall die and wont restart the only other code that has popped prior to this is for the speedometer that intermittently decides not to work please help we are a foster family that needs this van to work
I need a little more specifics to help. What exactly happened when it shuts down. Does it restart? you need to check for ignition fire when it shuts off. If no fire check ecu module. If fire and no fuel, pump or pressure regulator is faulty
Testimonial: "it wont restart but now that i have it in my driveway i can check for that spark how do i "check the ecu module" pump has been changed already so i can try to get the pressure regulator checked"
