There doesn't seem to be a 'latch' like other describe for oven door removal
Open the door look at the hinge where it goes into the receiver you should see a small hole place a small short screw in the hole each side now close the door slowly hold the door while closing you should feel the hinges release out of the receivers, to take the door apart you are going to have to remove these screws to do this take the box end of a wrench pull the hinge back to take pressure off screw remove screw
SOURCE: Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. [email protected]
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
SOURCE: How do you remove the glass front of the oven door
See page 34
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: cleaning glass in oven door
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. The glass slides out from the tabs and you can give it a good cleaning at this point. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Testimonial: "Thanks for the advice and it worked like a charm, like you said make sure that you take your time and it works TX "
