Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Controller failed when a bulb blew
The bulb on our QS2 series rangehood blew, and now the light is on at full intensity all the time. Banging around the various relays on the control board didn't do anything, and a new board is a $130 problem
  • Dan Phillips Jun 17, 2008
    Thanks for your response. I had arrived at the same conclusion, it's the $110 part that stings. Apparently there is no swapping out a dodgey relay for $10, which is the solution I was hoping for. As it now stands, I've got the $2 solution, an oven mit twisting the bulbs in and out to get light. While not glamorous, it works well enough. I'm a little put off by the notion that Nutone (or in my case Kenmore) makes a product that appears to consistently fail like this, and takes no responsibility for it, but I guess that's life.
  • 38 Answers
Control Board: Part # R111638 = $110.00
I do service calls for Broan-Nutone
Inventex Inc
Posted on Jun 14, 2008
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
I want to set up two household light (AC) both of which are to be controlled from one switch with a dimmer. can I connect the lights in in series or do I have to connect them in parallel with two separate...
The dimmer controls the intensity of the electric current flowing in the circuit, hence controlling the light intensity emitted from the bulbs. I believe a series connection with one switch will suffice.
Jul 23, 2011 | Office Equipment & Supplies
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Kenmore 63682300 Bulb blew now lights won't turn off
See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Light won't shut off
I have never reaplaced anything on the control board. But it is definetly the control board that is defective.
Part# R111638 = $110.00
I do service calls for broan-nutone.
Nov 11, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
1,578 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
