Cleaning the carb ,new fule diafram
My my ms 660 will start and run with breather off but die when u put it on and it blows gas out of the carb will
If it is blowing an excessive amount of fuel while it is running then the cylinder has aprobably worn down and the tolerences are bigger than they should be therefore you are getting fuel back out the carb. If it is leaking while shut off then you have a needle not seating in the carb correctly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
