Question about Crosley CE35100AA Electric Kitchen Range
Stove manuals for Crosley Electric Stoves
My mother-in law lost her manual for her Crosley range. I tried to get the self-clean cycle to work, but could not. I have no idea what model it is. It has a dial to turn to "Clean" on the left then a button on the right under the display. When I press the "clean" button the word "door" appears on the display, but nothing else happens. The lock does not engage and the lights to indicate the cleaning process or locking mechanism have engaged do not turn on. Can you help?
Thanks,
Maryellen
  • Dcgreentree Apr 21, 2008
    I have a crosley stove that is about 15 to 20 years old works great but have no manual on how to use self cleaning feature any instructions would be great.
    Model CWP 36500 70CF 10035
    Debbie
How do I operate the self cleaning function on my stove model
cs37500-1
Posted on Oct 26, 2010
Wfg36ilvq stove display shows "cool" and can not get it to work or even set the time.any ideas?
self cleaning stoves have a door latch mech that latches the door when cleaning (due to hi temps involved 4 safety) at the same time the display says clean and hence after clean cycle it says cool this will occur till the stoves internal temp reaches less than 100 degress , now stoves have to b insulated so cooling down can take many hours again this is 4 safety , now if next day stove still says cool then id say thre is a fault in the internal temp measurement of stove and it "thinks" stove is still hot
Dec 19, 2016 | Kitchen Ranges
-F-3 error message on stove
F-3 is open or shorted temp sensor probably due to using self cleaning mode, temps in self cleaning mode on some brands and models can reach upwards of 1000 F. replace temperature probe, and if problem ensues replace clock\control.
May 09, 2012 | Crosley Kitchen Ranges
No User's Manual
I have a Crosley csf395001 and no manual, how do I turn on self clean option
Mar 26, 2010 | Crosley Kitchen Ranges
Kenmore self cleaning stove: cannot open door after cleaning cycl
F9 is your oven sensor im sure.Also try to unplug your range and plug back in.Some times that works.Hope i helped:)
Mar 13, 2010 | Kitchen Ranges
Unable to clean my 5 yr old self clean Crosley oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Aug 31, 2009 | Crosley CE35100AA Electric Kitchen Range
Lost manual for Crosley self cleaning oven-HELP
Copy the below link into your browser and contact Customer Services, they should be able to email one to you for your model
http://www.crosley.com/service.do
Dec 11, 2008 | Crosley CE35100AA Electric Kitchen Range
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Self cleaning cycle
Between 3 and 5 hours. Most likely 3 hours unless yours has the adjustable setting for cleaning, then you can clean longer.
Jan 01, 2008 | GE JBP25 Electric Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
1,486 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
