I would like to install an AMC 360 engine
I just found out that all that you have to do is . You have three options to go with one change the bellhousing from a borg warner m12 transmission. two use and borg warner m12 transmission but use the yoke head from the m8 onto the yoke of the m12 yoke .Three use a chryler/amc tf727 torque command transmission.Use the yoke from the m8 weld the head on to the spline of the 727transmission weld the m8 tail section onto eather transmission and that way you can keep the torque tube suspension on your classic 770 with the 287.Your rear end should be an AMC 20 to stand the torque from the AMC 360 engine with about 350 hp .last but at lease get the trany mounts.
SOURCE: ( I only entered Concord
well u talking about compatibility of old ford cars. so its better if u check with a dealer.
SOURCE: id trans. borg warner basic-2 casting
Mostly came in s-10 or simular vehicle.Not vey heavy duty.I just bought one thinking I got a good deal,but as it turns out this is not a real desirable transmission.
SOURCE: rebuild manual
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-56_Service_Manual.pdf Thats it, I almost tackled that project, but since the car was my daily driver, I opted to have a shop do the work. I can recommend http://www.thegearbox.org/home.html I bought a rebuild kit from them, I also went with the Steel viper 3-4 shift fork since i had it out.
SOURCE: no clutch pressure on a hydraulic clutch system
look for leak....under the dash on the floor if its wet there its the master. Just follow rod from clutch peddle to master. Check the line and not sure if your slave is on the outside of the trans look there or if its in the trans see if its wet coming out of the bell housing (where trans meets engine) and replace that part and bleed system
