Press and hold Volume up and Power button at the same time until you boot into the Android system recovery.... Choose Wipe data/FactoryReset with your volume keys and then press the power button to confirm.
Is this android tablet 4.4 and above?
If yes, try hard reset.
1. power off tablet
2. press and hold power button and (home button) or volume+
3. release only the power button when you see it power on, keep pressing and holding the volume + or (home button)
4. You should see an android recovery menu
5. Select :Wipe data factory reset" with volume - key go down selection. then press power button once to Enter
6. Select : "Delete all user data" with volume - key. then press Power button as enter.
7. Will restore to factory data and "reboot system now"
8. Press "power button" once and it will reboot.
9. system will restart and load again, this time whait a while on "Android" boot logo and it will finish restoring.
10. all done.
note: use volume + or also try Volume - with power key or use the home button should be another button that looks like the power key.
hope this works for you. reply with your comments.
Try this.......
Ensure Device is off before performing the following steps 1. Press and hold the volume up key 2. Press and hold the power button 3. On the boot screen select the option Factory Data reset (using the volume keys) press the power button on the selection to begin the reset process.
Hello, Call support support for the tablet and see what they would do. If no help then call the manufacturer or the tablet and talk too the tech support. They will walk you thru trouble shooting and they will tell you what to do.
Before starting, make sure that the tablet is powered off. Not just in sleep mode. Now press & hold both the UP and DOWN volume buttons at the same time.
You may find it easier to hold the tablet in the landscape position on a
table or on your lap while you hold down both buttons.
Next press and hold the power
button until the tablet buttons light up. It will take a minute to
happen, but when they do immediately let go of the power button ONLY.
Keep holding down both the UP and DOWN volume buttons. You only have a
second to do this other wise the tablet will continue boot up as normal
and you will have to start again from step one.
After a
bit of holding down both volume keys the screen will show the Vizio
logo. Then the logo will change to a TRIANGLE with an exclamation mark.
Now you can let go of the volume buttons.
Tap the home button to pop up the boot recovery menu.
Follow the instructions to reset your tablet. Pressing the up/down
volume buttons allow you to scroll up and down the list. A quick press
on the power button will accept your selection.
Wait for the tablet to come up.
Try visit my blog if you want see video tutorial http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
Make sure the tablet is powered off
Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
There should be an option to factory reset or something to that affect
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
