Video Game Consoles & Games Logo
Anonymous Posted on Feb 10, 2015
Can i run windows 8.1 64mb if i have 32bit operating system installed ram 8gb with 2.97 usage x64-based prossesr
My games crash on windows 8.1 32mb
gofalltrades
Level 3:
Master:
  • Master 267 Answers
  • Posted on Feb 10, 2015
gofalltrades
Master
Level 3:
Master:
Answers
267
Questions
0
Helped
89189
Points
1605
You would have to install Win 8.1 64 bit from scratch; new copy with new license. Then you'll have to reinstall all of your old 32 bit programs, some may not work on 64 bits.
Testimonial: "i have windows 8 64 bit disk it same box but same key"
How do I re-format SanDisk 8gb Cruiser Glide
Open My Computer and select drive by right clicking on it, and choose Format.
1helpful
2answers
My computer is telling me I can not run an x86 build of this utility on a x64 platform. I am running windows 7. What do I have to do to be able to run this program for the new Futura CE-150
x86 means 32bit operating system , x64 means 64bit operating system.Windows is divided into to categories 32 and 64 bit. In your case you might be trying to install 32bit operating system's software or a application in an 64bit operating system running machine. If you are getting the above mention error message than it is clear that your window 7 is 64bit operating system and a 64bit operating system doesn't support 32 bit's software. You only can install software or application you are meant for 64bit supporting.
If you want to know more about 64 and 32 bit CLICK HERE
GOOD LUCK.
I have bought e games MahJongg Master 6. Have run the disc to install but the game wont run, tells me Cannot initialise graphics and cannot install graphics device. My system is HP pentium 2.7GHz, 2GB...
Mahjong 6 was produced in 2004 and will likely not be compatible with your operating system, operating systems that are 64bit are often less compatible with software than operating systems that are 32bit, especially with older software. One solution you can try is to:
  1. Right click the desktop shortcut for the game
  2. Click "properties"
  3. Click the "compatibility" tab
  4. Check the box next to "run in compatibility mode for"
  5. Select Windows XP
  6. Click Apply
This may allow the game to run by emulating an older operating system.
Window 7 is not work in my system
The first thing you should know is that what is your system Is it 32bit (or x86) or is it 64 bit (or x64). The 32bit Windows 7 should be chosen for 32bit System and like wise.
Then you should know the the processor and RAM of your System. If the processor speed is less than 1 GHz than it is a problem. If your RAM is less then 1GB the your PC will slow down. If your Hard disk is less than 16 GB free space than again you are going to have problem..........Similarly you should adhere to System and Windows compatibility details. If you do not have a system like this try or fall back to Windows XP.
Good Luck!
2helpful
2answers
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
2helpful
Vista x32 want to upgrade vista x64
microsoft provides upgrade discs from it's site (you should payteh freight).
If u are using Microsoft Windows Vista Home Basic, there is no way to upgrading.
else, the other versions allows u to upgrade.
remember: the only difference between 32 and 64 bit is the RAM memory usage (32 bit will not use more than 3,2GB RAM), and there are a lot of programs that won't run properly in 64 bit version .
1helpful
System crashes and i have to reformat after installing msn premium software on new 64 bit vista laptop
you can downgrade to 32bit. you would have to reinstall windows using a 32bit cd. i would recommend it you wont see much of a difference. all programs where originally made for 32 bit. the only difference between the two is that 64bit supports more ram. like xp pro; 32bit will recognize 3.25gb as ram even if you have 4gb installed but other than that not much difference. personally i dont like any 64bit systems nor vista... but with 32bit you will be able to run a wider range of programs with no problem
3answers
Windows XP Upgrade
completely different operating systems actually... as far as i know that upgrade would not be possible... a full install would be the way to go... back up all your data first.
the beauty of 64 bit tho is it basically allows you to add unlimited memory to your computer.
Robert
Memory Issue
yeah you should upgrade. Windows xp 32bit only support up to 3gb memory. You should upgrade to 64bit.
And your specs? Yeah it can run 64 bit operating systems or if you like, use Windows Vista x86 or x64 with Service Pack 1.
Top Video Game Consoles & Games Experts
Don A
Don A
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
