Need help lighting water heater ? does it work off battery ?
If it is electric, you do not have to light anything. If it was gas you would have to light the pilot light. Electric water heaters have elements. If you have no hot water it could be caused by no power to the elements (like circuit breaker tripped or fuses). Check to make sure the breaker is not tripped. If there is power, I would test the upper heating element using a multimeter. If you do not know how to do this, then you should probably get a professional to come help you.
