Question about HP PSC 2175 All-In-One InkJet Printer
Printer problem Hi No matter what i do i still get thye message "press enter to align print cartridges"Any ideas?Graham
  • Rosie Posie Nov 21, 2007
    Yes I have the same problem after purchasing and installing a new black ink cartridge.
  • donnpaula Dec 01, 2007
    Added another set of new cartridges. It seemed to print the alignment page okay...but only once. Now, no matter what I am afraid to use the option/setup method as problem is still there and the response to the option/setup method does not sound good.
    I tried using a dampened Q-tip to clean the electrical contacts with plain water...also no good. Problem still is there.
Print function
The printer prints alignment page; after enter button.
Place the printed page in scanned glass properly.
Press the scan button and wait untill the ON light stops blinking.
Now alignment is completed.
Mar 02, 2010 | HP PSC 950 All-In-One InkJet Printer
Hp all in one printer - printer head alignment problem
Try pressing the reset or off button for a few seconds. Failing that, unplug the printer for 15 min. Let me know if it works, if not, then I will guide you through other steps.
Nov 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
(Press Enter to Align cartridges)
after putting a plain paper in the paper tray then try pressing ENTER or OK button on the printer this will print the alignment page.
Please rate the solution
Jan 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer not working...
Press Enter and Menu simultaneously when align message is prompted on the All-in-One.
Dec 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
