Question about Brother MFC-3240C All-In-One InkJet Printer
Lines showing up on document after scanned
I have been scanning photos through the feeder and lines have been showing up after the document has been scanned. What is causing this?
  • Joyced Nov 12, 2007
    it is not a flatbed scanner - you can only feed into it. Not sure if I have the right model #. would this have anything to do with the drum?
  • 832 Answers
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Posted on Nov 12, 2007
  • Mix-it-up
    Mix-it-up Nov 12, 2007
    see here how to clean the glass:
Why I get lines on my photos jpeg
If lines appear when scanning/copying from document feeder only, you need to clean the narrow scan glass located to the left of the main glass. If lines are present when printing, could be a drum/developer problem.
Oct 06, 2014 | Toshiba E-studio 2500c Color Copier...
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Jun 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Line through scanned document when using the document feeder only
try cleaning the glass scan bar on the unit with a clean soft cloth.
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Black streaks are appearing on printed page when scanning
Do the lines only show up if you use the document feeder? If so, there is something on the strip of glass where the page is scanned. Open the top to reveal the large glass area. Then open the part where the paper feeds in when using the document feeder. It will flip open from right to left. There are two pieces to this, so make sure you grasp it as low as possible. You should see a small strip of glass. Clean all the glass with a SOFT cloth. Don't spray any cleaner onto the glass, rather, spray it onto the cloth if you need any.
Apr 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Brother MFC-3240C All-In-One InkJet Printer Logo
950 people viewed this question
James Cagle
James Cagle
Jim Keysor
