Fixing a broken glove box on a 2011 Toyota Venza may vary depending on the specific issue with the glove box. However, here are some general steps you can try:
Determine the issue: Inspect the glove box to identify the problem. Common issues with glove boxes include broken hinges, latches, or handles. Once you have identified the issue, you can proceed with the appropriate repair.
Replace the hinges: If the hinges are the problem, you can replace them by removing the old hinges with a screwdriver and installing the new ones.
Fix the latch: If the latch is broken, you may need to replace it. Remove the old latch using a screwdriver and install the new one.
Replace the handle: If the handle is broken, you can remove the old handle and install a new one. This usually requires removing the trim panel to access the handle mechanism.
Check for loose screws: If none of the above steps work, check for any loose screws that may be causing the problem. Tighten any loose screws to see if that fixes the issue.
Seek professional help: If none of these steps work, it may be best to seek the help of a professional mechanic to diagnose and repair the issue.
Remember to be gentle with the glove box during the repair process to avoid causing further damage.
Hi Mel, I looked for a manual for your fridge but couldnt find one. These jobs are pretty similar - regardless of brand however.
You should first deremine if your model does indeed support swapping the hardware to allow the door to swing the other direction. Look at the points of attachement for the handles and hinges on the door and the fridge body itself. There are typoically pre drilled holes for fasteners in these parts on the opposite side - but have plugs or covers over them to minimize their appearance. if you have these tell tale indicators present - you're good to go.
The process will require removal of all products stored on the doors of the fridge and freezer compartments, and placing in a thermal container or cooler.
The hinges consist of one at the top, one at the bottom and usually one in the center that engages both the bottom of the top door and the top of the bottom door.
At the top, you may need to remove a bezel or cover to gain access to the fastener head(s). Many times these are hex head screws, but could be any type really. Two, 3 or more fasteners may be used to hold the top inge to the fridge. Once the screws are loosened / removed the tops door will shift - so be ready for it (or have afriend support it while you remove the fasteners). The doors are surprisingly light - a thein meta outer jacket wrapped around a lightweight drame, lots of insulation and plastic is it really is. Lift the top door up and away from the center hinge pin. You may find one or more spacers or washers made of metal or more likely - nylon. Remove these and set aside as they will likely be needed to put back in place when the hardware is reversed.
The lower door is being help by the center and bottom hinges now. You should have access to fasteners holding the center hinge to the fridge. Support the bottom door as you loosened and remove the fasteners on the center hinge If you are unable to access the fasteners of the center hinge, try the fasteners on bottom hinge instead. If you get the center hinge loosened, you should be able to lift on the door slightly to roll it out from between the center and bottom hinge. otherwise, when the bottom hinge fasteners are removed, the door will drop and be free from the fridge. Look for similar spacers or washers on the bottom hinge pin that yuou found on the top of the center hinge pin and save them.
Remove any remaining hinges from the fridge.
Remove door handle hardware from both doors and remove plugs / covers from the opposite side of the doors. Secure the door handles to the otherside and insert the plugs and covers into the holes that had previously been used to fasten the handles.
Remove the covers / plugs from the fridge and insert into the opening that previously fastened the hinges to the fridge. Swap any covers / plugs on the doors for hinges if needed.
Reinstall the hinges and doors in reverse order of removal. If the bottom hinge was last to come off - it is first to go on. Reinstall the spacers on the pin. The bottom door is placed on the bottom hinge pin. Place the center hinge pin into the recess of the top door and secure the hinge to the fridge. Place the spacers over the top pin of the center hinge. Place the top door recess over the center hing pin. Align the top hinge with the recess on the top of the door and insret fasteners through top hinge into fridge. Hand tighten all fasteners. Operate doors and check for rubbing, binding, etc. Adjust number and location of spacers as needed to allow doors to swing without scraping or binding. Once satisifed, tighten all fasteners. Adjust feet of fridge as need to allow the doors to close by themselves if left open by accident. Restock fridge & freezer.
I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
There are some little clips that hinge the screws on the top and bottom of each handle.
Remove these little covers with a small flathead screwdriver.
Now remove the screws holding the freezer and refrigerator handles on.
Now pop the screw hole covers on the side of the frig/freezer you will using.
Now place and fasten with screws the handles on the other side of the frig/freezer door.
Now remove the top freezer hinge first by removing the 3 screws on top.
Now pull up on the hinge (save the spacer).
Now pull up on the freezer door.
Now remove the screws on the middle hinge.
Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
Now pull up on the frig door and set to the side.
Now remove the screws on the bottom hinge (save the spacer).
Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
The switch
Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
Fasten the middle hinge.
Place freezer door on the middle hinge.
Put the freezer door in it's natural position to make putting the top hinge on possible.
Now you can put your standard screwdriver in the hole in the middle of the metal where you removed the doorknob, turn the screwdriver, and now your door will open.
To remove the door springs you just take the bottom front cover off of the dryer.
There are a couple clips towards the top corners that you can release with a flat blade screwdriver.
Once you get that bottom front cover off you will see the springs
Unhook springs from hinge. Remove bolts and hinges
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to; http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
there are what are called door "cams" on the bottom of the doors. One piece is on the bottom of the door and the other one is on the hinge. Both pieces need to be replaced and it is possible both your doors may need them. The parts come as a hinge assembly. That means you need to replaced the hinges on the bottom and they should come with the piece that goes on the bottom of the door also. You may also have a blocked defrost drain. There is a hole in the center rear, under the evap plate there where you see the dripping. that may need some air pressure blown through it to clear it. remeber, ever time the unit defrost, you will get that water.
I took other hinge apart. Removed front glass by removing handle -bar. Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly. Removed control panel assembly by taking out 5 screws. Started with one side hinge first. Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside. With the same screwdriver engaged a little hinge to the notch of larger arm.. Did the same thing for other hinge. Put the upper screws back, Tightened bottom screws back. Put the front glass and handle-bar back. Put control panel assembly back. Now it is ready to go. Door is Fixed. Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
